[VideoStudio X6] plugins/extras license
vincents
- processor: i5-2340
- Video Card: Intel 3000
- Hard_Drive_Capacity: SSD
Hello,
I search contact to Sale Support but I cann't find. I wonder as buy the VideoStudio X6 Ultimate beacouse it has interesting extras/plugin but I cann't find nothong about license or have I can use/activate. Maybe included are the keys for this plugins?
How can is test extras?
And i have something different question. When I must flip video and when I want use variable speed in window I watch original video (not fliped) why? What I need do for watch flip video in preview window?
Re: [VideoStudio X6] plugins/extras license
There is no extra license for the extras in VideoStudio - when you install them they appear in the 'FX' library.
Do you mean 'flip' or do you mean reverse if 'flip' when you applied the 'Flip' filter did you drag it from the library and drop it onto your video in the timeline
vincents
"flip" - I have mine rotate video. sorry for confusion.
For the extras I understand it is all full version. so I buy directly from the manufacturer.
How do you rotate the video
do you double click on the video in the timeline - then use the icons I have indicated in the image below :=
vincents
Yes I use rotate in options. And when I rotate video in variable speed window video isn't rotate
YES - the variable speed window does show the video is not rotated - but when you click OK in the variable speed window and go back to the timeline your video is still rotated - it is just the way the speed window shows it.
vincents
but this makes it difficult to work of edit video. why in this window video isn't rotate? I think, without offending anyone, it is fault. Other pop-up windows, for example effects, show the same video as in preview. It is strange.
ok, What about licenses for extras. I understand that no need any key and all extras is full version. Which version Video essentials you add to VSx6?
If you buy the VideoStudio X6 Pro Ultimate the extras come with it - you do not buy them separately.
Sorry if you find working with the speed change difficult - it is the way it is.
vincents
maybe it is good sugestion to corect with next update or SP.
i have another question, can I synchronize timeline with effect window?
You could add the suggestion to the "Wishlist" here :- http://forum.corel.com/EN/viewtopic.php?f=1&t=49893
I do not understand your question - what you do in the effects window will happen in the timeline.
