Hello everybody!
I need to ask you a favour. Could anyone convert the attached file to Corel 11 file version? I need to get these zodiac signs laser engraved, and this company uses Corel 11 only. I tried to do this in Corel X3 trial version, but I couldn't open it.
Pdf version of that file contains symbols and text - text can be deleted if it causes any problems during conversion, only symbols matter.
As I can't upload 1,6mb file - here's a link where it's stored: LINK REMOVED BY ADMINISTRATOR
Could anyone convert this file to Corel 11 format please?
Re: Could anyone convert this file to Corel 11 format please
OK - first thing I've done is disable the link so that no one accidentally goes there
I am very concerned that your link appears to go to a file with an html extension - typically used by people who try to spread viruses.
Why does it have a strange name - very suspicious -
What exactly is the file - what is it's type - you talk about pdf that is not a video so cannot be converted to a video for use in a video editor. If it is a pdf file and you want the images you can do that easily by taking a snapshot in the pdf reader and pasting it into an image processing programme - "paint" even - no need for a conversion programme.
What do you mean by Corel 11 format - IF you mean Corel video Studio 11 that can accept a whole range of video formats - But if you are talking about lazer cut signs then I don't think you mean VideoStudio at all - you probably mean Corel Draw - and that we do not discuss here - that is on a different forum
I see you have hosted it on 4Shared - I cannot access that site as I am not a member and am certainly not going to join just to help you
the link posted points to a file called "/znaki_zodiaku.html "
So - a little more detail and explanation please.
Hello Brian,
Thanks for your reply. I'm afraid i posted this message in the wrong section. The file i wanted to upload is a .cdr (i mentioned a pdf file because I have this file both in pdf and cdr version). Could you tell me if there's a section on this forum ('Paint Shop Pro' perhaps), where I can get help with this, or is this a totally wrong site?
.cdr is a Corel Draw file - so anyone with Corel Draw should be able to open it
you could try asking on the Corel Draw forums here :- http://coreldraw.com/forums/
