ASP deletes wrong file
Bugs & Suggestions
scorpi11
operating_system: Linux
System_Drive: Q
processor: Intel Core i5-2400
Video Card: Intel HD2000
Monitor/Display Make & Model: Eizo S2110W
Post by scorpi11 »
I noticed the following:
1. I select 2 images (one JPG, one CR2) in the filesystem view
2. I send them to the "Download" queue
3. I go to the library
4. I select the just imported images in the library
5. I press the "delete" key on the keyboard
Now, both images are still in the library. However, the JPG file is removed from the path where is has been downloaded from.
So ASP deletes wrong files. I consider this a real bad bug. The original file is deleted. If the user deletes the file in the catalog afterwards and assumes that it is still in the original place then the image is completly lost.
This happens with 1.2.0.7 on Linux.
scorpi11
System_Drive: Q
Re: ASP deletes wrong file
Post by scorpi11 »
It looks like the last file which is selected in the filesystem before sending multiple files into the Download queue is deleted.
scorpi11
System_Drive: Q
Post by scorpi11 »
I seems like this is an issue known for a long time:
http://forum.corel.com/EN/viewtopic.php?f=94&t=46287
Things like this make me cry.
