PSPX6 Print Layout icons oddity
Joelle
ram: 16 GB RAM
Hard_Drive_Capacity: 1TB
Post by Joelle »
In my version of X6 32-bit, there is a problem with the icons in Print Layout, they're not the normal icons, but one's used when tying as script to an icon
I have re-set X6, using the Shift key method, but the problem is still there.
Very odd and annoying.
I can use the menus and print, but those icons don't belong there.
Anyone else see the same thing?
Joëlle
Joëlle
(PSPX9 )
MarkZ
ram: 8 GB
Hard_Drive_Capacity: 500 GB
Re: PSPX6 Print Layout icons oddity
Post by MarkZ »
Joelle:
I've had the icons on the standard and tools bars scrambled although the commands were in the correct location. In some instances clicking on an icon brought back the correct one. This cleared up spontaneously - I can't remember if it was after a coupe of days or just rebooting.
Mark
Joelle
ram: 16 GB RAM
Post by Joelle »
The scrambled icon syndrome ™ .. only appears here if I have accessed Manage (which is usually accidentally as I never use it), when I then go back to the Edit workspace all the customized toolbars are a mess, half the icons are missing and the rest doesn't resemble what was there before.
Re-loading the saved workspace returns everything to normal.
All very odd.
Will submit a ticket (again).
Thanks Mark.
Joëlle
Joëlle
(PSPX9 )
jsj
Post by jsj »
I've had the same oddity in Print Layout. Contacted Corel support and, after many messages, I was able to reproduce it whenever I activate large icons in toolbars.
Solution: don't select large icons for toolbars.
This is a known bug that, hopefully, will be fixed in next update.
Joelle
ram: 16 GB RAM
Post by Joelle »
Thanks for confirming that :-)
Joëlle
Joëlle
(PSPX9 )
