I am one of the people who found that PSP X6 has problems converting embedded colour spaces.
After some difficulties I eventually got a case number which meant that I could get some support.
I supplied a problem description and sample files to first level support. This is the reply that I received:
I then said that this wasn't ok and got passed to level 2 support. And this is what I got back:The file was saved as 16 bit TIFF with ProPhoto as the color space, this one is a big factor because PaintShop Pro (X5 or X6) has its own color space and is only supporting RGB color space. It is normal for PaintShop Pro to convert your image to sRGB because that is the embedded color space. Also, I suggest you to contact ProPhoto to know what do they support or if they support PaintShop Pro.
Please be advised that color shifting is normal due to the color space that is being used by a specific program (e.i. PaintShop Pro). Colors that are not within the range of RGB color space will be determined as imaginary colors.
Again I persevered and it got passed to the development team.As far as I understood the topic correctly, you use a certain colour profile. This makes it difficult, because we have no support for colour management for no Corel software (even our Draw customers who work with Draw in a professional way need to ask somebody who knows how CM works.
That PSP has some problems with professional colour profiles is known. Regarding the engine, nothing has changed and PSP X6 still uses the default RGB profile for Windows and the same engine as X4 and X5.
I asked when there would be a fix and got this backI have received reply from the development team and learned that there have been made changes to the tiff engine because of other issues related to tiff.
Eventually these changes may have an impact on your problem with ProPhoto.
Unfortunately, from a point of support view, there is nothing that we can do. I will keep an eye on your issue and collect more data.
Now I have asked for a refund.Because it's not a failure in PSP directly but when you use another color profile, and there are only a very few customers that have that problem, there will no fix solution. Currently, the development team can't work on that topic, because there are other things more important. Sorry I have to say as it is.
