Grey sky to blue: best approach?
terrypin
motherboard: Asus Z170 Pro 4
processor: Intel Core i7 6700K 4.0GHz
ram: 32 GB
Video Card: None - uses built-in graphics
sound_card: HD onboard sound card
Hard_Drive_Capacity: 4.256 TB
Monitor/Display Make & Model: iLyama Prolite E2403WS 24" 1920x1200
Corel programs: Paint Shop Pro 8; Paint Shop Pro 2018
Post by terrypin »
A while ago I had some great help here on turning a blue sky to grey. Now I'm trying the more familiar reverse,
I'm doing it on this Google Earth Street View image:
https://dl.dropboxusercontent.com/u/401 ... mVan-1.jpg
This is my first attempt:
https://dl.dropboxusercontent.com/u/401 ... luesky.jpg
I made it by selecting the sky, lightening it and then using the air brush with a blue chosen from memory (and a second time with a slightly darker blue). Apart from setting opacity at 40% I made no other changes to what was already there:
https://dl.dropboxusercontent.com/u/401 ... ttings.jpg
What method do the experts use please? Simplicity over high realism would be my priority, but it would be good to have both! Is there perhaps a well endorsed script?
Terry, East Grinstead, UK
Using PSP 8 & PSP 2018 under Win 10
photodrawken
ram: 16Gb
Hard_Drive_Capacity: 324Gb
Re: Grey sky to blue: best approach?
Post by photodrawken »
Hi Terry,
Unless you're an excellent artist, I would not attempt to paint clouds and sky.
My first thought was to just replace the sky:
1. Promote the background to a normal layer.
2. Select the sky.
3. Delete the sky.
4. Paste a new sky as a new layer, moving it below the former background layer.
Of course, the lighting of the scene does not match the new sky, so I boosted the clarity, vibrancy and contrast so it would look more like a sunny day:
Uploaded with ImageShack.us
If you want to retain the original sky:
1. Select the sky.
2. Apply an Adjust...Color...Channel Mixer, boosting the blue:
3. Apply an Adjust...Brightness and Contrast, adjusting both the Blue channel and the RGB:
to get this:
Edit:
I think I overdid it with the Levels adjustment for the Blue channel -- that sky looks much too "sweet".
Ken
terrypin
ram: 32 GB
Post by terrypin »
Thanks a bunch, Ken, that first method is brilliant - embarrassed I didn't think of it myself!
I used the sky from a photo I took in same area at similar time of day:
As this will only be seen for about 6 seconds as part of a DVD, I'm happy with its quality.
photodrawken
ram: 16Gb
I realize this is absolutely of no help for your current project, but in case anyone reading this thread is wondering about creating a cloudy sky, I thought I'd share this result:
I used and old (and somewhat rare) version of Kai's Power Tools -- KPT6 (yes, "6"), from the days when it was distributed by MetaCreations. Its "SkyEffects" is a plugin that allows you to build up your own cloudy sky, with beaucoup options. Although it can't create puffy cumulus clouds or mare's tails, it does an otherwise excellent job of creating a believable cloudy sky.
Ken
