Jan Shim wrote:Now I remember why I didn't proceed with the scripts from before even though they worked, I was and still am getting this repeatable error each time I close PSP. It would take about five seconds or so before the error appears. Not sure what to do about it.
The attachment 2015-04-30_111103.jpg is no longer available
When I run the script in PSP X7 Ultimate SP2, on my WIN 8.1 64-bit machine but using the 32-bit X7 program, I do get an error message several seconds after closing the X7, but it's different from yours (see attached). In my case I just have to click the X on the error window to close it - a bit inconvenient but easy. I don't get the error closing X7 unless I run the scripts.
In your case you likely have to go through that whole routine of closing the program with windows looking for a solution, so that's more of an issue. I think I'll PM the script creator and see if he knows why, but as I'm kind of busy getting ready to go away for a few days perhaps you could do so and point him to the posts and images we have posted here showing the problem.
Also, what version of PSP are you using, and what operating system? That might explain the difference between what happens to the two of us.
EDIT: By the way, I don't get the error if I run Viveza 2 using the regular plugin with the original workaround (the one that caused Viveza to work but caused a color shift in the preview unless the preview was set to 33%). But considering that the error window that opens for me can be easily dismissed with no problems - and X7 closes properly - I prefer having the plugin work with proper color rendition at whatever zoom level I want.
And it's not like I'll be using those scripts all the time, so only an occasional issue anyway for me.
JoeB
