Is there a way in PSPX5 or X6 to rename a picture (or string of pictures) so that I can have a "Constant such as VACATION_" followed by the create date from the EXIF data as YYYY-MM-DD followed by a sequence number?
Thanks,
Larry
Batch Rename Question
jaxman43
- motherboard: PEGATRON CORPORATION 2AC2 2.00
- processor: 3.40 gigahertz Intel Core i7-2600
- ram: 8 GB
- Video Card: NVIDIA GeForce GT 520
- Hard_Drive_Capacity: 3 TB
- Monitor/Display Make & Model: HP 2311
- ram: 6 GB
- Hard_Drive_Capacity: 500GB
- Corel programs: PSP: 8-2023
Re: Batch Rename Question
Yes, very easily in fact.
File - > Bath Rename
Along the bottom you'll see a button labeled 'Modify" which will let you change the renaming value.
You can add "Custom Text" and change that value to "VACATION_" then add the Date finally add the Sequence. And you've got exactly what you asked for.
At least I think so, I'm not sure if Date is the date of creation or modification.
jaxman43
- ram: 8 GB
Thanks Levi,
I'll try that with a pic that has different dates in the two fields.
Larry
Larry
jaxman43
- ram: 8 GB
Actually, it seems to be putting current date.
- ram: 6 GB
Well that's just....weird. And useless.
Next best thing would be a script. Otherwise there are many free programs that can do this as well.
- hartpaul
- ram: 8 Gb
One free program you can use is Irfanview. www.irfanview.com
A mini tutorial is here:
http://www.hartpaul.com.au/IRFANVIEW/batchrename.htm
jaxman43
- ram: 8 GB
Thanks hartpaul. Downloaded and tried irfanview, but even in the tutorial you had to manually enter the date as part of the name. I was looking for a way to pull the original or create date from EXIF information, perhaps using some variable name, but I can't seem to find a way to do it without knowing some programming language and scripting.
Thanks anyway.
Larry
Thanks anyway.
Larry
- hartpaul
- ram: 8 Gb
Whenever I do a shoot and have a lot of images from the one day, I renumber and name them on that day. I only have to add the date once in the format style I desire. Thereafter the name and date follows with the images when I dsplit them up to other folders and each image has a unique name/ number that will never be repeated.
Trying to use an automatic program to extract the date from the Exif information (if saved) is another thing and would be nice.
maxa
- motherboard: Asus P8H67 REV3
- processor: i5 2500
- Video Card: Asus ENGTX550 Ti DC
- sound_card: On board
- Hard_Drive_Capacity: 2TB + 2TB
- Monitor/Display Make & Model: Acer AL2216W
I have used Flexible Renamer: http://hp.vector.co.jp/authors/VA014830 ... /FlexRena/
You can first add constant and after that exif data.
