Having a new problem with X3.
Starting today, when I try to add borders to a raster image, I get the following message:
"Command could not be completed because the document type is unsupported"
Same thing happens if it is "Merged Visible"
If the image is flattened or is a background image all works fine.
I do not have this problem in X2.
Can someone help me out?
I did reset the workspace, as sometimes that helps, but not in this instance.
tia
Unsupported Document Type in X3
Cassel
- ram: 16Gb
- Corel programs: PSP 8 (JASC) to PSP 2023
Re: Unsupported Document Type in X3
There is an option to automatically merge (Flatten) an image when that format is required.
Go to File > Preference > General Preferences and under the Auto-Action tab, you should find Flatten image into a single layer, and check the Always button. This will then automatically execute the change for you to apply the Border or other effect that needs the image to be a single background layer.
Cassel
https://scrapbookcampus.com
