VIDEOSTUDIO PRO X5 ULTIMATE STARTUP FAIL
gregsandpaul
operating_system: Windows 7 Starter
System_Drive: S
Post by gregsandpaul »
I installed VS PRO X5 Ultimate last year and run it without any problem until some weeks ago where I have got crash when launching VS X5.
Trying to run it now I get :
i) The VS X5 panel during 1 second and then the screen becomes gray
ii) And an error message appears "this program stopped running windows is trying to solve the problem".
Could you help me please
Many Thanks
Re: VIDEOSTUDIO PRO X5 ULTIMATE STARTUP FAIL
and welcome to the forums
There were some issues starting Video Studio related to your browser.
Read this info
Dump file Error in VideoStudio Pro All Versions during launch
gregsandpaul
System_Drive: S
Many thanks for your reply.
I applied the recommendation but I still have the same problem"VS pro X5 start and fail".
Best regards, Greg.
Hi Greg
I do not have a definite answer to why VS 5 does not run but will go through some things I would try before re-installing the program.
As I have already said the Browser Manager does cause some problems. I did a search of the knowledge Base and found more info, most refers to the Browser Manager
000015088 - VideoStudio Pro X4/X5 failed to launch with crash error
Error in VXCODER.DLL
Manually resetting Corel VideoStudio Pro X5 to its Factory Default Setting
Manually Removing Corel VideoStudio Pro X5
http://corel.force.com/index/articles/e ... y=NoFilter
Clean_up utility for X5
Another post regarding X5 also contains a cleanup file for X5, you should not need to do the Manual Remove from the above link?
http://forum.corel.com/EN/viewtopic.php ... ve#p270803
Finally Re – Install Video Studio X5
Hope this helps?
