Version 4 Upgrade Problem.
KevinD
Post by KevinD »
I upgraded this morning from DVD MF version 3 SE, which came with a Hauppauge WinTV-PRG-150 video capture card, to version 4. In the "Video Capture" window I get now sound on the video monitor, only video. When I try to set the Capture "Format" to "DVD- GQ 4:3 ...." an information dialg window pops up and says, "This format template is not supported. It will use the default format." hit "OK" on the dialog, and the "Format" goes to "MPEG". If you hit the capture button now, another information dialog pops up and says "MPEG capture does not accept HCW2 codec. Please select a suitable codec from the video format list. ...".
I did notice in the "Advanced Settings" - "Change Capture Plug-in" , in version 3 SE there was a "Hauppauge WinTV-PRG-150 ... " plug-in, that is not available in ver 4.
If this is the problem, I didnt see any way of adding the plug-ins.
Thanks for the help,
Kevin
jcc
Post by jcc »
There is an update pack on the DVDMF4 update page relating to Hauppauge which would probably help
http://www.ulead.com/tech/dmf/dmf_ftp.htm
KevinD
Post by KevinD »
That did the trick,Thank You John
