How Can You Tell If You Have Service Pack 1 Installed
dbz2000
processor: InTel[R] Core [TM] i9 7900X 3.60 Ghz
ram: 16 GB
Video Card: GTX 1070
sound_card: NVIDIA High Definition Audio Device
Hard_Drive_Capacity: 1.5 TB
Monitor/Display Make & Model: Dell ST 2310 Analog
Corel programs: VideoStudio 2018_ VideoStudio Paintshop
Post by dbz2000 »
Just curious of how to determine if you have the Service Pack installed. Each time I close down VS Pro 16 Ultimate, I get that annoying, your update is ready to install. If I click on it to install it, I get the message that the version cannot be determined. No changes made and it exits. I check the little cog wheels on the Corel Guide an went to About to check the version number and it reads VS Pro 16.1.0.45 Ultimate. Does it state anywhere whether the Service Pack is installed? Not a big deal, but would like to get rid of that message whenever I close the program. Many thanks!!
DBZ2000ny
"Instead of trying to add years to your life; try adding life to your years"
Re: How Can You Tell If You Have Service Pack 1 Installed
Post by BrianCee »
The second block of numbers - that is the 1 - indicates that service pack one is installed - that figure will always increment to show the number of the latest service pack installed.
The "the version cannot be determined. No changes made and it exits." message is also Corels strange way of telling you that the update you are trying to install is already installed.
dbz2000
ram: 16 GB
Post by dbz2000 »
Many thanks Brian Cee. Be well! :D
