When I try to combine 2 videos to play over each other (i.e. one full screen one anchored in a corner) the overlay track plays at an accelerated rate with no sound, whereas the main video will play as normal. However if I switch them around the same problem arises, the overlay video plays fine the main accelerated with no sound.
If I play them separately they will both play fine. The video I am trying to anchor was recorded with a webcam and therefore may be the problem.
If I need to give more details w/ specs etc. I'll give as much as possible but there could be a simple solution I am missing. Any suggestions would be appreciated. Thanks.
Overlay track speed
lbkaze
- motherboard: Micro-Star International Co. Ltd. MS-16GA
- processor: Intel R Core TM i5-3230M CPU 2.60GHz 2.60GHz
- Hard_Drive_Capacity: 478.36GB
- Monitor/Display Make & Model: 15.6"FullHD 1920x1080 NVIDIA GeForceGT650M 3D
canuck
Re: Overlay track speed
Try a test with a non-webcam video, perhaps the same video in the overlay as on the main track.
It would be helpful if you could tell us the properties of both types of video. Right click on the clips and select Properties, then copy them here, please -- or Upload a screen grab of each Properties box.
Can you also tell us a bit more about what you did in the overlay track. Did you just move the smaller image down into one corner, or did you use the Picture-in-Picture (PnP) filter?
