I wont shrink from this problem!
Hi everyone
I am trying to use DVD Shrink to back up one DVD to another. (the original was created and burnt using DVD Shrink)
I select open disk and then full disk back up.
After 21% of encoding you get an error message stating “DVD Shrink encountered an error an cannot continue. Failed to read file Q/ overlapped I/O operation in progress”.
Can anyone help me on this? I thought this was a fairly regular operation and I have done it once or twice before without any problems.
Many thanks as usual
Antonio, Anna y Eduardo Felipe
Antonio y Anna
THoff
heinz-oz
Many thanks for your help
Many thanks to one and all. I will try your advice.
Thanks again
Thanks again
Antonio y Anna
Hi Antonio,
I'm still interested to know which version of Shrink you are using. Reason I ask is I've been using Shrink, v. 2.3 since '03 and like you also use ME as my OS. Your problems and questions interest me because of our common OS and use of Shrink.
If the forum had PM capability back I would have gone that route instead of on the forum.
Thanks,
Erock
Thanks,
Erock
Yes Antonio, that's the latest ver., it just came out. I never updated because v. 2.3 has worked flawlessly for me from day one. I'm not one to fix what works. That's why I took my time to upgared from VS6 to VS8 and I won't go to VS9 until things settle down a bit.
I'm curious, have you used the ISO splitting feature Shrink added in 3.2.0.14? It was intended for users with a Fat32 file partition, like our ME OS. It's supposed to split an ISO that is over 4gigs and also create an .mds file that will link the 2 ISOs. I believe DVD decrypter can use the .mdf file. If you haven't done so, you should check out the forums on AfterDawn & Digital Digest.
Erock
Erock
Thanks Erock
erock
I did not know about the spliting feature. I will check it out.
Thanks again
Thanks again
Antonio y Anna
