PSPx6 Bugs and Fixes
flagpole
motherboard: Gigabyte B450 AORUS ELITE DDR4 USB 3.1 RGB
processor: Ryzen 2600
Video Card: RTX 2060
sound_card: on board
Hard_Drive_Capacity: 6.5TB
Monitor/Display Make & Model: Iiyama 27"
Re: PSPx6 Bugs and Fixes
Post by flagpole »
Trilliana wrote:Hello,
flagpole wrote:1) Chromasub sampling - why does nobody at corel understand this? do they not use the product. which one of the following do we think was saved with no subsampling and which one was on maximum?
Please see this message earlier in the thread:
http://forum.corel.com/EN/viewtopic.php ... 60#p285460
There was a whole discussion about this, the bug seems to be older than X6.
it certainly is.
Tup3x
motherboard: Asus P8Z77-V
processor: Intel Core i7 3770K
Video Card: GeForce GTX 1070
sound_card: Sound Blaster Zx
Hard_Drive_Capacity: 5 TB
Monitor/Display Make & Model: Samsung S24E390HL
Corel programs: PSPX9
Post by Tup3x »
it certainly is.
Oh yeah... It's been there at least since least since X4 (if I remember correctly some update broke it).
The setting is reversed (i.e. 4x4 2x2 2x2 means no chroma subsampling when it should be 1x1 1x1 1x1) and it's bugged in JPEG optimizer and in "save as" window.
http://forum.corel.com/EN/viewtopic.php ... 09#p276509
Zacabeb
motherboard: ASUS B450-F
processor: AMD Ryzen 5 3600
ram: 16 GiB
Video Card: nVidia GeForce RTX 2060
sound_card: RealTek Integrated Audio
Hard_Drive_Capacity: 3 TB
Monitor/Display Make & Model: Philips 236V4
Corel programs: PaintShop Pro X6, PaintShop Pro 2021
Post by Zacabeb »
I too would like to see the chroma subsampling list order bug fixed. I never save JPEG in 4:2:0 as I consider chroma subsampling to be unjustifiably destructive in many cases.
Have there been any signs anybody at Corel reads this thread?
flagpole
Post by flagpole »
Zacabeb wrote:I too would like to see the chroma subsampling list order bug fixed. I never save JPEG in 4:2:0 as I consider chroma subsampling to be unjustifiably destructive in many cases.
I can see why you would assume that, most people would. but actually the issue has existed for so long and been reported so many times, updates, version upgrades have come and gone in that time, and there has been no change.
unfy
motherboard: Asrock B75 based
processor: i7 2600
Video Card: Gigabyte R9 270 2GB
sound_card: onboard
Hard_Drive_Capacity: 120GB
Monitor/Display Make & Model: ASUS / LG widescreen panels
Post by unfy »
Cross posting this into this 'bug and fixes thread' just cause it seems appropriate.
Concerning the render / redraw bug when zoomed in on an image and moving a floating section around ...
The solution I discovered for this problem was to disable Tabbed Documents. (Window Menu -> Tabbed Documents). With tabbed documents turned off, the on screen corruption goes away.
The source thread:
http://forum.corel.com/EN/viewtopic.php ... 44#p289601
Tseg
operating_system: Windows 8.1
Post by Tseg »
Tadjio wrote: 2) clear the Cache under Reset Preferences
See my posting
"Nuke the Cache - Slow Start-up for X6 SP2"
This. This was the only solution that worked for my chronic spinning cursor. My PSP X6 program is on my SSD and my Library/Pictures are on my HDD. By clicking Clear Cache under Reset Preferences my 64-bit system now finally functions properly... nice long term work-around. Not even sure what that cache function provides?
Tseg
Post by Tseg »
See my posting
Disregard, problem has returned... spinning cursor will not go away... one other observation, if I close when the spinning cursor is spinning, I cannot reopen the program unless I close it through Task Manager first.
JoeB
ram: 8 GB
Hard_Drive_Capacity: 4.6 TB
Post by JoeB »
LindaSue wrote:Is anyone else getting screen artifacts on the X6 workspace? The border around the workspace area shows whatever is on my Windows desktop behind the PSP window. It's as if that thin border is transparent. It does seem to be an intermittent glitch because it's not always that way. It seems like it happens when I've first opened X6 and eventually goes away after I've opened and closed few images. It happens with both workspace colors but it's more noticeable with the dark scheme.
I just shut down X6 and reopened it and the glitch returned. What you see below is part of this forum around the border of the workspace:
When the glitch goes away, there isn't a contrasting border around the workspace at all.
I know this is old, but also have this intermittent issue with X7. I have found that minimizing to the taskbar or clicking the Restore Button next to it, and then maximizing again, usually fixes the problem. I think it has something to do with a maximized PSP with docked toolbars and palettes causing the workspace area to not quite fit on some screens (maybe by a pixel or two), and sometimes it happens when an open image is up against one of the sides or top/bottom of the workspace window. Why resizing PSP fixes the issue (at least temporarily) is something I can't explain.
JoeB
Using PSP 2019 64bit
