PSPx6 Bugs and Fixes
- karebai
- processor: AMD DualCore A9-9410
- Video Card: AMD R5
- Hard_Drive_Capacity: 1TB
- Corel programs: PSP7;PSPX;PSPX9;PSP2019 Ultimate
Re: PSPx6 Bugs and Fixes
Something else I've come across is when moving an image there are times it gets to the point where I'm not sure which is actually the REAL image, other times fragments are left behind, making it difficult to edit. In the sample image below the segment on the far right is part of the actual image.
- Attachments
- Image1.jpg (24.04 KiB) Viewed 6959 times
DigitalDave
- motherboard: Asus Rampage Extreme
- processor: Q9650
- ram: 4GB
- Video Card: Radeon HD 4870
- sound_card: SoundMax Pro
- Hard_Drive_Capacity: 600GB
- Monitor/Display Make & Model: Dual Dell 22" 1920x1080
There's a bug with PNG format files that when saved, convert from pixels per inch to pixels per cm regardless as to settings in preferences. This bug has been reported for PSP 9, PSP X, PSPX1, PSP X2, PSP X3, PSP X4 and PSP X5 where support staff log the reported technical issue as "Closed" without addressing it. The bug appears in PSP X6 as well and it's really easy to reproduce - resize any PNG at 200 ppi and save it. Close the file, open the file, then check image info: ppi is now ppcm. This only seems to occur for PNG files. A second frustrating aspect is the insufficient rounding used for the conversion so that it's not completely accurate.
If anyone knows how to submit a bug report or to whom it should be addressed, please post a reply. There's nothing for this at the Corel web site and it's not a support issue users should have to pay for.
LindaSue
- motherboard: Gigabyte
- processor: 2.71GHz AMD Athlon II X2 215 processor
- ram: 3 GB
- sound_card: Realtek AC97 Audio [onboard]
- Hard_Drive_Capacity: 1320 GB
- Monitor/Display Make & Model: Asus MX279 HDMI 27-inch
- Corel programs: Paint Shop Pro X2, X4, X6
My X6 CD was delivered today and I just finished customizing the workspace and checking things out. I skimmed through this thread but I saw no mention of the problem of images disappearing from the tray(s). Is there any way to save a tray? Every time I close X6, the images disappear from all of my trays. Does SP1 fix this?
I've also noticed something odd in a couple of dialog boxes that pop up when I open or close X6. In both of the screenshots below, there's an image missing and all I see is a red "X". What is supposed to be there?
Using Paint Shop Pro versions 5, 6, 7, 8, 9, 12, 14, 16
LindaSue
- ram: 3 GB
I've figured out the tray issue and I do seem to recall reading this somewhere. The images in a tray will only be saved if you add them via the Collections tab of the Navigation palette. If you add them via the Computer tab, they aren't saved.
SJS
- motherboard: Dell Inc 0KWVT8 A03
- processor: 11th Gen Intel Core TM i7-11700
- ram: 16 GB
- Video Card: NVIDIA GeForce GTX 1660 Ti 6GB GDDR6
- sound_card: Onboard Realtek Codec
- Hard_Drive_Capacity: 4 TB
- Monitor/Display Make & Model: DELL U2412M
- Corel programs: PaintshopPro 2022 Ultimate
Just installed PSP X6 in hope of better 64-bit performance & hit the scanner "wall" (the nasty shock of no 64-bit TWAIN support).
I tried PSPX6-64 using WIA: File | Import |From Scanner or Camera, with my Epson GT-15000 scanner. Scan window pops up, preview works, I set the resolution & the scan runs, but nothing in PSP: no window or tab, and PSP X6 is not responding. Via Task Manager I try "switch to task" & get an error popup & PSP is still unresponsive, so I close it w/Task Mgr.
Now PSPX6 will not start, but crashed right away w/the "has stopped working" message immediately.
Ugly, & I am frustrated! Eventually I think to restart two services (WIA & Wintab), and can run PSP X6 again. Next time the WIA File import works fine... must have been standing on the wrong foot before.
. Every little bit helps !!!!
Noticing the reference to Wintab32.dll in this error? WIA worked fine in PSP X5 with the newly scanned file open in PSP.Problem signature:
Problem Event Name: APPCRASH
Application Name: Corel PaintShop Pro.exe
Application Version: 16.0.0.2
Application Timestamp: 525f66b8
Fault Module Name: Wintab32.dll
Fault Module Version: 5.3.2011.1014
Fault Module Timestamp: 4e97e3bc
Exception Code: c0000005
Exception Offset: 0000000000021e2f
OS Version: 6.1.7601.2.1.0.768.3
Locale ID: 1033
Additional Information 1: f275
Additional Information 2: f275cd28b452303c2df1b27442e6148a
Additional Information 3: 75bc
Additional Information 4: 75bce6c55242e42d65bb97521051effa
Read our privacy statement online:
http://go.microsoft.com/fwlink/?linkid= ... cid=0x0409
If the online privacy statement is not available, please read our privacy statement offline:
C:\Windows\system32\en-US\erofflps.txt
BUT WIA limitations & interface are unacceptable! My new workaround: a desktop shortcut to PSPX6 32bit with a script on the command line that runs Import--> TWAIN Acquire. It starts my EPSON scanner s/w for me (if I remember to turn the scanner ONGrazie wrote:I can in 64bit X6.Ozric wrote:Has anybody got a scanner to work in the 64 bit version ?
I've not used the TWAIN acquire since PSP3. X5 couldn't TWAIN and now neither can X6. I've trained myself to use the : File | Import |From Scanner or Camera - option.
This is working fine with my EPSON 580.
Grazie
SJS
- ram: 16 GB
Do you know if the WIA default scan resolution can be changed?Grazie wrote:I can in 64bit X6.Ozric wrote:Has anybody got a scanner to work in the 64 bit version ?
Grazie
When I use : File | Import |From Scanner or Camera, I have a default setting of 100dpi. I scan frequently so resetting the resolution every time is extremely tedious. My web search seemed to indicate no access to the default WIA settings!
---Update: WIA is inadequate. There is no convenient access to settings, no color corrections, etc. So back to TWAIN, with PSPX6 32-bit
I've got the same problem. I tried to figure out when problem appears and I realized that it's always then when image is greater than the workspace. So when I zoom in and try to move a layer then it's not "refreshing" correctly (as it showed karebai). I must zoom out to see where the layer was moved. It's a horrible bug and actually I can't use new version of PSP because of that. Please fix it as soon as possible. I guess this problem appeared with a new workspace which now have some free space (background) around the image.karebai wrote:Something else I've come across is when moving an image there are times it gets to the point where I'm not sure which is actually the REAL image, other times fragments are left behind, making it difficult to edit. In the sample image below the segment on the far right is part of the actual image.
Condoman44
- motherboard: Z87-G55
- processor: 3.60 gigahertz Intel Core i7-4790
- Video Card: On board
- sound_card: On board
- Hard_Drive_Capacity: 500G SSD
- Monitor/Display Make & Model: ViewSonic VS14880
- Corel programs: PSP 2019
I am using Windows XP Pro SP3 with max memory. Since I installed PSP X6 every so often the windows control buttons (min, max, restore and sometimes parts of the scroll bar and other icons and check boxes) become corrupt. They may be displayed as blank or multicolored. (They still work though.) Logging off then on fixes the issue. The picture is what the 3 buttons look like. For some reason the image would not post.
My research also found that deleting C:\Documents and Settings\Your User Name\Local Settings\Application Data\Iconcache.db and then logging off and on will fix it.
http://www.condoman.us/PSPX6&WinControlButtons.jpg
Bonjovicrzy
- Corel programs: PSP 2018 & PSP 2022
I have a few problems .. in the last few days When you use Effects / Artistic Effects/ Balls and bubbles / it does not open and the whole program freezes and I can not use or close the program unless I close the program on the taskbar/ start task manger area I run both 32 and 64 bit psp and and it does it in both .. have Windows 7 Ultimate I checked and it seems like everything is ok in storage and file location .. the other options under Artistic Effects works and with no problem
plus at times and when I sometimes opens or closes the program a blank discovery center pop up pops up and freezes and have to use the computer start task manager to cloee it I have it checked to not show the pop up but it pops up anyway
plus I am also having the same problem with the move tool that karebai & pankamil is having I have all the updates for psp and hotfix fo the zoom bug that was released recentlykarebai wrote:Something else I've come across is when moving an image there are times it gets to the point where I'm not sure which is actually the REAL image, other times fragments are left behind, making it difficult to edit. In the sample image below the segment on the far right is part of the actual image
sleenie
- motherboard: MSI X58 Pro
- processor: 2.67 gigahertz Intel Core i7 920
- ram: 6GB
- Video Card: ATI Radeon HD 5700 Series
- sound_card: SB Audigy
- Hard_Drive_Capacity: 554.02 Gig
- Monitor/Display Make & Model: DELL 2007FP
Fit to Image Bug
I just recetnly upgraded and am trying to set up my Wrokspace just as in PSPv5.
I have never used the tabs. When I open the images in the workspace I sometimes want to make them smaller. I like to see multiple onesd at a time. Before my upgrade I never had a problem. Now it seems that when I scroll with the mouse to make it smaller, instead of the window getting smaller only the image does which leaves me with a large border around it. A real pain to work with.
My upgrade download included SP1.
Has anyone got an idea on how to get around this?
Kathy_9
- Hard_Drive_Capacity: 2TB
That was a known issue and Corel issued a hot fix you can download here http://forum.corel.com/EN/viewtopic.php?f=56&t=52219
MarkZ
- motherboard: Intel DQ67SW desktop
- processor: Intel Core i7 i7-2600 3.40 GHz
- ram: 8 GB
- Hard_Drive_Capacity: 500 GB
- Monitor/Display Make & Model: LG Flatron E2241
- Corel programs: PSP 2018 X9 X8 X7 X6 ASP3 ASP
Re: Fit to Image Bug
Go to Window in the menu and select Cascade. Under Window you also have the option to tile the windows. Cascade will allow different sizes of pictures to cohabit the workspace.sleenie wrote:I have never used the tabs. When I open the images in the workspace I sometimes want to make them smaller. I like to see multiple onesd at a time. Before my upgrade I never had a problem. Now it seems that when I scroll with the mouse to make it smaller, instead of the window getting smaller only the image does which leaves me with a large border around it. A real pain to work with.
There was a problem in SP1 that the window frame did not zoom with the image. Go to http://forum.corel.com/EN/viewtopic.php ... &start=105, page eight, second last post, for a link to a download to fix that problem.
Mark
sleenie
- ram: 6GB
Thanks to all who responded. Guess I didn't read far enough. Downloaded and it worked Thanks again.
sleenie wrote:I just recetnly upgraded and am trying to set up my Wrokspace just as in PSPv5.
BillnVA
- motherboard: Asus P8P67
- processor: i7-2600K 3.40GHz
- ram: 8.0 GB
- Video Card: Dual Radeon HD6850
- sound_card: Built In
- Hard_Drive_Capacity: 3.5 TB
- Monitor/Display Make & Model: Dell 2407, Dell 2412
PSP X6 - In manage mode when I pulled the preview window to a second monitor it worked fine until I closed the program and reopened it. Now when I select manage mode the preview window pops into view for an instant on the second monitor and then disappears. Does anyone know how to get the window back. Maybe to get it to redock.
FrenchPSP
- processor: Intel I5
- ram: 6 GB
- Monitor/Display Make & Model: Ilyama Prolite T2250MTS
Hello Bonjovicrzy!Bonjovicrzy wrote:I have a few problems .. in the last few days When you use Effects / Artistic Effects/ Balls and bubbles / it does not open and the whole program freezes and I can not use or close the program unless I close the program on the taskbar/ start task manger area I run both 32 and 64 bit psp and and it does it in both .. have Windows 7 Ultimate I checked and it seems like everything is ok in storage and file location .. the other options under Artistic Effects works and with no problem
I have the same problem than you. Balls and bubbles crashes PSP each time I use it. I have Windows 7 Professional 64 bits and I run PSP X6 64 bits as well. The downloading of the service pack 1 doesn't change anything.
