[SOLVED] ASP on ubuntu 64 bits
FalCT60
Post by FalCT60 »
Hello,
I'm rather new under Linux. I installed 13.10 and after playng with it (especially making it connect using a WNA 3100...), I decided to go on with ASP.
I went to the site which offers the choice between 3 distros : Linux RPM, Debian 32 bits and Debian 64.
I first tried with the RPM, which failed due to the need to install many i386 libraries - well, I run Ubuntu 13.10 64 bits -.
I then downloaded the 64 bits Debain packet and tried to install automatically, but then I got a message arguing it couldn't achieve because ia32-libs dependancy cannot be satisfied (bad english traduction, sorry, but I hope you'll understand anyway).
No matter : sudo apt-get install ia32-libs will surely do it. Unfortunately, it returns that :
Reading package lists ... done
Building dependency tree
Reading state information ... done
No version of the package ia32-libs available, but it exists in the database
data. This usually means that the package is missing, it has become obsolete
or is only available from another source
However the following packages replace it:
lib32z1 lib32ncurses5 lib32bz2-1.0
E: "ia32-libs" package has no version that can be installed
No need to say I tried to install the suggested replacement libraries, but still the installation failed because of ia32-libs imssing.
At this point, my brain is not able to understand anything anymore, so I come here for help.
Thanks in advance for being indulgent,
J.-L.
afx
operating_system: Linux
System_Drive: N/A
Video Card: FirePro 4900
Re: ASP on ubuntu 64 bits
Post by afx »
FalCT60 wrote: I went to the site which offers the choice between 3 distros : Linux RPM, Debian 32 bits and Debian 64.
Why would you want to install an RPM on a Debian based system?
That is just an invitation for too much work ;-)
No need to say I tried to install the suggested replacement libraries, but still the installation failed because of ia32-libs missing.
Hmm, my 13.04 system has ia32-libs-multiarch installed. And that was a machine I installed from scratch.
cheers
afx
spoilerhead
System_Drive: N/A
Hard_Drive_Capacity: 13.5TB
Post by spoilerhead »
You said you're using Ubuntu 13.10, if that's correct, then there's no ia32-libs (yet ?) As can be verified here: http://packages.ubuntu.com/search?keywo ... ection=all
also compare to:
http://ubuntuforums.org/showthread.php?t=2164734
Still, you're using a development version of ubuntu, so such unexpected behavior is to be expected :)
my ASP Plugins - donation button ( send beer! :) )
linux,7d, glass and a huge mug of coffee.
If you got any immediate problems with my plugins, don't by shy on contact me on GoogleTalk.
FalCT60
Post by FalCT60 »
Hello,
I think I need some time before I understand Ubuntu's behaviour and how to behave myself in order to avoid experimenting with something I am not familiar with.
My first try was with a v10 IIRC, and I directly stepped to 13.04 and, still experimenting, I am now running 13.10 (or even higher, since I upgraded yesterday via terminal command).
I thank you both for helping.
J.-Luc
afx
System_Drive: N/A
Post by afx »
13.10 is not official yet. You would need to deliberately install a development build.
Not recommended unless you are into hardcore alpha testing.
cheers
afx
kross
System_Drive: N/A
Post by kross »
I'm running Debian sid 64-bit, and had a similar issue trying to instal ASP 64-bit .deb. It complained about missing ia32-libs. So I installed ASP 32-bit .deb, and it works just fine. Give that a try.
Hope this helps!
-- Kevin
shurito
System_Drive: N/A
Post by shurito »
On 64bit-Debian testing my way to install is:
1. Add i386-architecture
Code: Select all
sudo dpkg --add-architecture i386
2. Reload your repositories
Code: Select all
sudo apt-get update
3. Install the 32-bit package
sudo dpkg -i ASP-i386.deb
4. Install missing dependencies
Code: Select all
sudo apt-get -f install
The ia32 aren't existing any more, multiarch is the way now: https://wiki.debian.org/Multiarch/HOWTO
rhadamanthys
System_Drive: Z
processor: i5-3470
Video Card: Nvidia
Hard_Drive_Capacity: 2TB
Monitor/Display Make & Model: DELL 2560x1440
Post by rhadamanthys »
kross wrote:I'm running Debian sid 64-bit, and had a similar issue trying to instal ASP 64-bit .deb. It complained about missing ia32-libs. So I installed ASP 32-bit .deb, and it works just fine. Give that a try.
Hope this helps!
-- Kevin
You can manipulate the dependencies of any deb
https://geekwentfreak-raviteja.rhcloud. ... b-package/
So I have a 64bit ASP and no complaints from the package manager
rhadamanthys
FalCT60
Post by FalCT60 »
Cool! I try this ASAP (but not before thursday alas), then I come back there and report.
Edit : could manage to do it today, and it wors fine. :D
Many, many, many thanks to you all.
New edit from 2013 09 10 : restarted from scratch with ubuntu 12.04, things are a lot easier. 8-)
J.-Luc
