Linux user experience.
sismo
operating_system: Linux
System_Drive: N/A
motherboard: 990FXA-GD65
processor: AMD FX-6100
ram: 16gb
Video Card: [Radeon HD 6670 2gb
Hard_Drive_Capacity: 3 x 750gb
Monitor/Display Make & Model: dell u2913wm
Post by sismo »
Hi, I'm having several crashing during a standard workflow (processing 100 photos, 10 crashes). I'm using Ubuntu 12.04 64bit. If you are another Linux user, do you have the same problems? What distribution are you using?
SISMONDA, Fernando Miguel
email: f@sismonda.com.ar
TWITTER: @sismonda
SKYPE: fmsismonda
fb fkr G+ www
afx
System_Drive: N/A
Video Card: FirePro 4900
Re: Linux user experience.
Post by afx »
12.04 64bit. No issues.
Are you using any plugins?
cheers
afx
sismo
System_Drive: N/A
ram: 16gb
Post by sismo »
I'm lading at startup
  • asPluginManager
  • Equalizer
  • GradFilter
  • Mix3
  • Vigne
  • Wavelet Shaperpen3
  • zPerspector
My default settings are (the extract were I define the plugin
  • bopt:warpon="true"
  • bopt:rn_smooth_enabled="true"
  • bopt:WaveletSharpen2.bSphWaveleton="true"
  • bopt:WaveletSharpen2.bSphWaveletAmount="25"
  • bopt:WaveletSharpen2.bSphWaveletSharpenClarity="true"
Thanks for your time afx
TWITTER: @sismonda
SKYPE: fmsismonda
fb fkr G+ www
afx
System_Drive: N/A
Post by afx »
That should be ok ;-(
Do you see any specific in the log file when it crashes?
cheers
afx
sismo
System_Drive: N/A
ram: 16gb
Post by sismo »
Nothing special (segmentation fault). I'm using Ubuntu 12.04 64bit, which distribution are you using?
TWITTER: @sismonda
SKYPE: fmsismonda
fb fkr G+ www
afx
System_Drive: N/A
Post by afx »
The same ;-)
I assume you are batching 100 images right? Or are you talking about crashes while working on the images?
And do you use OpenCL?
cheers
afx
spoilerhead
System_Drive: N/A
Hard_Drive_Capacity: 13.5TB
Post by spoilerhead »
- Try turning off openCL (File -> Preferences -> Hardware Acceleration -> Use OpenCL.
- Append your ~/.AfterShotPro/AfterShotPro.log (after a crash)
- Try running ASP with this script from a console. When it crashes, just type bt[enter] This gives you a call stack, thereby hinting what module crashes.
Code: Select all
#!/bin/bash
BIBBLE_INSTALL_PATH="/opt/AfterShotPro"
LD_LIBRARY_PATH=${BIBBLE_INSTALL_PATH}/lib:${LD_LIBRARY_PATH}
XLIB_SKIP_ARGB_VISUALS=1
export LD_LIBRARY_PATH
export XLIB_SKIP_ARGB_VISUALS
echo "Install Path:          " ${BIBBLE_INSTALL_PATH}
echo "LD_PATH:               " $LD_LIBRARY_PATH
echo "XLIB_SKIP_ARGB_VISUALS:" $XLIB_SKIP_ARGB_VISUALS
if [ -x "${BIBBLE_INSTALL_PATH}/bin/AfterShotPro" ]
then
    cd "${BIBBLE_INSTALL_PATH}/bin"
    gdb "./AfterShotPro"
else
    echo "didn't run it (obviously)"
fi
exit 1
my ASP Plugins - donation button ( send beer! :) )
linux,7d, glass and a huge mug of coffee.
If you got any immediate problems with my plugins, don't by shy on contact me on GoogleTalk.
sajnox
motherboard: Intel DBS61
processor: i5 2.8
ram: 12GB
Video Card: NVidia 620
Hard_Drive_Capacity: 1.3TB
Monitor/Display Make & Model: Samsung XL23
Post by sajnox »
I've followed the instructions to create the file with the script but I don't get ASP to run
Code: Select all
Install Path:           /opt/AfterShotPro
LD_PATH:                /opt/AfterShotPro/lib:
XLIB_SKIP_ARGB_VISUALS: 1
GNU gdb (GDB) 7.5.91.20130417-cvs-ubuntu
Copyright (C) 2013 Free Software Foundation, Inc.
License GPLv3+: GNU GPL version 3 or later <http://gnu.org/licenses/gpl.html>
This is free software: you are free to change and redistribute it.
There is NO WARRANTY, to the extent permitted by law.  Type "show copying"
and "show warranty" for details.
This GDB was configured as "i686-linux-gnu".
Para las instrucciones de informe de errores, vea:
<http://www.gnu.org/software/gdb/bugs/>...
Leyendo símbolos desde /opt/AfterShotPro/bin/AfterShotPro...hecho.
(gdb)
And it stays there.....what am I missing?
sajnox
processor: i5 2.8
ram: 12GB
Post by sajnox »
Problem solved!
DIsabling OpenCL has an impact over performance with a total improvement over stability
Linux Users? Which Video Cards are you using? Open CL Enabled? Stability?
afx
System_Drive: N/A
Post by afx »
OpenCL on Linux is even more problematic than on Windows, as the server grade drivers are not available. On Windows one can at least buy server grade cards with appropriate drivers.
On my quad i7 Thinkpad with an Nvidia card I can actually reduce performance with OpenCL.
On my quad Phenom Windows box, using a FirePro V4900, I get a 25% performance boost.
cheers
afx
algreen345
Post by algreen345 »
I get crashes every time I try to delete more than 5 files at once regardless of whether I have OpenCL enalbed or not. Quite frustrating.
EOS
System_Drive: N/A
motherboard: Gigabyte
processor: Core i7-3930K
ram: 12GB
Video Card: Nvidia
Monitor/Display Make & Model: 2x Samsung SyncMaster 21 inch
Post by EOS »
I/O-threads to high?
is that with the version 1.2.0.7 ? downgrade if possible ;-)
kumsa
System_Drive: N/A
motherboard: Dell Vostro V131
processor: i5 2.4 Ghz
ram: 8 G
Video Card: Nvidia
sound_card: Dell Laptop
Hard_Drive_Capacity: Terabytes
Monitor/Display Make & Model: Dell U2312HM, Acer
Post by kumsa »
No probs with the latest ASP on Ubuntu 12.10
I'm actually loving ASP, now that it reads the CR2 files for my Canon 6D.
spoilerhead
System_Drive: N/A
sajnox wrote:Hi,
Code: Select all
(gdb)
oh sorry, i forgot:
you got to type "run" and hit enter
