Hi, I have been a VS user for a long time now. I am currently using VSPro X5. I have an Intel Core i7-3770K overclocked to about 4.3GHz. I am running a little tuning utility program by intel to validate that when using VSPro X5 it is indeed utilizing only 1 core and about 19% of the CPU. This is irregardless of whether or not I am editing or encoding video. I have selected all of the hardware acceleration options and optimizations to no effect.
I also use MainConcept's encoder to render certain video and have validated that all 4 cores are engaged during the process and about 65% of the CPU is utilized.
I downloaded and installed the trial version of X6 and ran it and used it to process video with the same results as X5.
I am running 64 Bit Win7 Ult.
I am wondering if I am doing something wrong. Am I missing something?
For the sake of comparisons, an AVI file converted to MPG (720x480, 1500kbps) is converted by:
MainConcept at about 200fps
VSPro X5 at about 30fps
Only one core of a multi core cpu utilized
Natal
- motherboard: Asus P8Z77-V deluxe
- processor: i7 3770K 4.37 Ghz
- Video Card: Gigabyte GTX680 OC 2GB
- sound_card: System board
- Hard_Drive_Capacity: 40 TB
- Monitor/Display Make & Model: Samsung SyncMaster S27A850D (2650x1440)
Re: Only one core of a multi core cpu utilized
My computer has the same processor and is overclocked to about the same amount.
Using the Asus monitor, transcoding a clip to Bluray uses both threads of each core (ie 8 virtual cores) at ~90% efficiency each for H.264 and ~70% for mpeg2. Transcoding to "same as" (mp4/H.264) used all 8 at ~85% efficiency.
What is your CPU temperature? Is it overheating? Running all 8 virtual cores gets the CPU very hot in short order, and if you don't have adequate cooling it may be throttling.
Canon Vixia HF G30; Sony RX100M5; Samsung NX1; Nikon P900
Videostudio X6
Creative Cloud CC
Videostudio X6
Creative Cloud CC
Hi, thanks for your reply. The CPU temps are within reason and the the CPU is stable at stress tests of 100% core use. So, that's not the problem.
What I noticed, recently, was that, if I am transcoding video using VS X5 with only one track in the main video track, VS Pro will encode using all cores. However, if I add a video or img file into track 2, VS X5 will no longer use all 4 cores. I experimented with different file types to see if that would improve the encoding efficiency, but nothing really changed. For example:
Test #1
Main track: video_file.m2t
Encoded to video_file.mp4 (using iPhone HD settings) ---> fast conversion (4 cpu cores @ ~ 65%)
Test #2
Track 1: pic_file.bmp
Encoded to video_file.mp4 (using iPhone HD settings) ---> slow conversion (1 cpu cores @ ~ 25%)
Test #3
Track 1: video_file2.m2t
So, from what I'm seeing, VS5 will not allow for muticore processing when more than 1 track is being edited or converted.
Test #1
Test #2
Test #3
