Panasonic GH3 mp4 60fps file can't be added
- aljimenez
- motherboard: Dell Inc. A08 4.16.2014
- processor: IntelCore i7-4790 3.60GHz 4Cores 8 Logical Proc
- ram: 24GB
- sound_card: AMD High Definition Audio
- Hard_Drive_Capacity: 500SSD+2TB
- Monitor/Display Make & Model: Three monitors, all Dell brand, one 4K
- Corel programs: Visual Studio, Paintshop
Here is Mediainfo for file that VS X6 nor X5 can handle. It simply dies as soon as the file is placed on the timeline. Does anyone see any reason this Panasonic GH3 created file can't be used in VS? (60p editing is enabled)
General
Complete name : P1020993.MP4
Format : MPEG-4
Format profile : Base Media / Version 2
Codec ID : mp42
File size : 70.1 MiB
Duration : 21s 21ms
Overall bit rate mode : Variable
Overall bit rate : 28.0 Mbps
Encoded date : UTC 2013-07-31 02:08:40
Tagged date : UTC 2013-07-31 02:08:40
PANA : DMC-GH3
Video
Format : AVC
Format/Info : Advanced Video Codec
Format profile : High@L4.2
Format settings, CABAC : Yes
Format settings, ReFrames : 2 frames
Codec ID : avc1
Codec ID/Info : Advanced Video Coding
Duration : 21s 21ms
Bit rate mode : Variable
Bit rate : 27.1 Mbps
Maximum bit rate : 36.9 Mbps
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 59.940 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.218
Stream size : 67.9 MiB (97%)
Color primaries : BT.709-2, SMPTE 274M, SMPTE 296M
Transfer characteristics : BT.709-2, SMPTE 170M, SMPTE 274M, SMPTE 293M, SMPTE 296M
Matrix coefficients : BT.709-2, SMPTE 274M, SMPTE 296M
Audio
Format : AAC
Format/Info : Advanced Audio Codec
Format profile : LC
Codec ID : 40
Duration : 21s 21ms
Source duration : 21s 35ms
Bit rate mode : Constant
Bit rate : 128 Kbps
Channel(s) : 2 channels
Channel positions : Front: L R
Sampling rate : 48.0 KHz
Compression mode : Lossy
Delay relative to video : -17ms
Stream size : 321 KiB (0%)
Source stream size : 322 KiB (0%)
General
Format : MPEG-4
Codec ID : mp42
Duration : 21s 21ms
PANA : DMC-GH3
Video
Format : AVC
Codec ID : avc1
Duration : 21s 21ms
Color space : YUV
Bit depth : 8 bits
Audio
Format : AAC
Format profile : LC
Codec ID : 40
Duration : 21s 21ms
Bit rate : 128 Kbps
User for more than 10 years.
Re: Panasonic GH3 mp4 60fps file can't be added
Hi Al. Unfortunately, I can't really penetrate that MediaInfo detail to see if there are any difference between it and other 60p AVCHD. But have you installed any disc which came with the camera? I ask because at one stage in the AVCHD stakes a couple of years ago, Panasonic was doing a lot of tweaking to the AVCHD codec it uses. Yes, it was still H.264, but with an apparently unique Panasonic twist. However, I simply don't know if they have now gone over to the standard h.264 codec.
My GoPro Hero 3 also films in the same format, using h.264 and the same audio too. I have no trouble inserting it in the X6 timeline and editing it, and even outputting it in the same format (Same As First Clip). But X6 still won't allow me to make a Custom Template using the Add function (pointing to a clip with those properties) -- and of course it would make a template for those properties made in the normal way either. So there is obviously still some way to go in Video Studio's handling of AVCHD 2.0 files.
- aljimenez
- ram: 24GB
Thanks for your feedback Ken.
I had been doing some light edits of the video clips that the camera has been creating, and then writing new mp4 files from Lightroom after the edits. The Lightroom generated files work.
This is the first time I have attempted to insert the mp4 files that come out of the camera without any conversion and encountered the problem. I have not installed any codecs from Panasonic, nor any software from them.
Since Lightroom and Windows Media Player can play and lightly edit the files out of the camera, I suspect the problem is in VS. I have tried two other laptops, one running Windows 8, with VS X6 and all fail when this file is inserted in the timeline... Al
Is it possible to make a very short clip and upload it to a site like Dropbox, so that we can play around with it at this end. I can also test it in Sony Movie Studio 12, Cyberlink PowerDirector 11 and Magix 2013.
- aljimenez
- ram: 24GB
I'll do that when I get a chance... Al
Edit: Here's dropbox link: https://www.dropbox.com/s/35trgjbljldl20b/P1030010.MP4
- aljimenez
- ram: 24GB
Dropbox link to file that causes VS X5 and X6 to end abnormally right after it is inserted in the timeline:
Yep... sure stops X6 cold!
I'll run some experiments later today (I have a busy morning) and get back to you...
I was so curious about this that I ran all three of the above-mentioned programs, and none of them had any problem at all with the clip. So it is quite obviously something specifically to do with Video Studio, and at a guess, it would have to be the H.264 codec used by VS. However, I still can't think why...
erdna
- motherboard: Gigsbyte H81M
- processor: I7 4770
- ram: 16GB DDR3
- Video Card: Intel HD4600
- sound_card: Intel display audio
- Hard_Drive_Capacity: 1TB 7200rp
- Monitor/Display Make & Model: Panasonic TX32cx600e
And strange enough the file works in VSX2...
- aljimenez
- ram: 24GB
Thanks for trying this in X2. Obviously something has broken since X2...erdna wrote:And strange enough the file works in VSX2...
- aljimenez
- ram: 24GB
Is anyone getting this
General Error
SQL ERROR [ mysql4 ]
Too many connections [1040]
An sql error occurred while fetching this page. Please contact an administrator if this problem persists.
It seems the website is having difficulties for me.
General Error
canuck
Yes, I have been getting that message frequently over the last couple of days. Also the site is very, very slow in responding. It sometimes takes over 1 minute before a page updates.
I reported the Board problem to Corel a couple of days ago, but then it appeared to come right again for a while. But back to the same problem again. (In fact I just got that General Error msg when I first tried writing this reply. Tried again and the reply page appeared!!)
On the substantive issue of the VS codec problem, I will also refer this directly to the Corel exec in charge of VS development to see if they can come up with a solution.
- aljimenez
- ram: 24GB
Thanks Ken... AlKen Berry wrote:I will also refer this directly to the Corel exec in charge of VS development to see if they can come up with a solution.
