How to turn on 'Fit to window'
leeguy
Post by leeguy »
On my zoom toolbar the command 'Fit to window' is faded out and does not function. I have set my window preferences to allow this functio yet it does not work. I want my rulers to fit to the image. What must I do?
Re: How to turn on 'Fit to window'
Which version are you using? In my X5, that button is active and works. I have not made any adjustments to the default settings to achieve this.
Forriner
motherboard: ASUS Z170M-PLUS
processor: Intel Core i5-6400
ram: 16 GB
Hard_Drive_Capacity: 1250 GB
Monitor/Display Make & Model: Philips Brilliance 272b 2560 × 1440
Corel programs: PSP 2023
Post by Forriner »
If you click on the menu Windows, if Tabbed Documents has a check mark, click on it to uncheck. If that's the problem it should help.
leeguy
Post by leeguy »
Ken Berry wrote:Which version are you using? In my X5, that button is active and works. I have not made any adjustments to the default settings to achieve this.
PSPX5
Don't think that is it. In my X5, Tabbed Documents is checked, but as I say, Fit to Window is active and works as advertised.
Forriner
ram: 16 GB
Post by Forriner »
Ken Berry wrote:... Don't think that is it. In my X5, Tabbed Documents is checked, but as I say, Fit to Window is active and works as advertised.
You're right, I should have mentioned that it's a quirk in X4. I does surprise me though, that Corel corrected it in X5. Miracles do happen :)
leeguy
Post by leeguy »
Turning off " Tabbed Windows" worked. Thank you A minor issue ...but the title background area at the top is now blue; would be better if it were grey as in PSP3
