auto add random transition in X5
Ken Veal
motherboard: msi mpg z390 gaming edge ac lga 1151 ddr4
processor: 360 gigahertz Intel Core i9 900K
ram: 32 GB
Video Card: EVGA GeForceGTX 760 2GB GDDR5 PCI E 3 0
Hard_Drive_Capacity: 1250GB SSD
Monitor/Display Make & Model: Samsung U28E90 28” UHD 4k
Corel programs: PaintSPro2021Ult.PhotoMirage.VS.2020 Ult
Post by Ken Veal »
I have decided some way through a long slide show to change via pref. to have the transitions auto added.But it has not worked, am I going about things the wrong way here?
canuck
operating_system: Windows 8.1
Re: auto add random transition in X5
Post by canuck »
I don't think you can add the random transitions after you have already created the slideshow, at least I have not found a way. Setting it in Preferences seems to apply only to any new images you add.
Transitions are only added when inserting clips to the timeline.
As canuck says clips already on the timeline are not affected by auto insert transitions these have to be done manually.
You could however drag several to the library creating a copy, delete them from the timeline.
Then drag the clips from the library to timeline, transitions will be inserted.
Suggest you make a copy of the project before moving/deleting clips
Ken Veal
ram: 32 GB
Post by Ken Veal »
Perhaps I should have given more detail.Up until a certain point I was adding cross fade transitions manually.It is then after adding more images (jpeg pics) that I did not want anymore cross fades but wanted random transitions and thought it would be much quicker if they could be added automatically.
Ken Veal
ram: 32 GB
Post by Ken Veal »
my method
1 Select all images with no transitions
2 Drag to library
3 Delete those from timeline
4 Drag clips back to timeline
5 Random transitions are inserted
Thanks !
