If I can come up with the test images can someone do the calculations? I tried to follow the instructions in the Lens Calibration: A complete guide how to calibrate a lens. thread but I think that's over my head.
Here is a zip file on my dropbox account with the files.
https://dl.dropboxusercontent.com/u/682 ... 20test.zip
Lens Profiles
df
- ram: 64gb
- Hard_Drive_Capacity: 1 Tb
Lens Profiles
Regards, Dan
Hobgoblin
- System_Drive: N/A
Re: Lens Profiles
You might consider exploring the options on this link: http://wilson.homeunix.com/calibrationdf wrote:Anyone?
I don't know if the results returned can be inserted in to an ASP/Bibble Calibration table but it might be worth a try.
HTH,
R.
afx
- System_Drive: N/A
- Video Card: FirePro 4900
Re: Lens Profiles
Us the scripts referenced in the thread, it is dirt easy.
cheers
afx
cheers
afx
df
- ram: 64gb
Re: Lens Profiles
Scripts don't run.afx wrote:Us the scripts referenced in the thread, it is dirt easy.
cheers
afx
cheers
Regards, Dan
afx
- System_Drive: N/A
Re: Lens Profiles
Why not? What is the error message?df wrote:Scripts don't run.
cheers
afx
df
- ram: 64gb
Re: Lens Profiles
Windows doesn't recognize it.
cheers
cheers
Regards, Dan
afx
- System_Drive: N/A
Re: Lens Profiles
My condolencesdf wrote:Windows doesn't recognize it.
That stuff is so trivial under Linux....
It would e actually quite easy to just set up a VM with a current Suse or Ubuntu distro for those things.
cheers
afx
df
- ram: 64gb
Re: Lens Profiles
I see, so why don't you just run things through and tell me what you get?afx wrote:My condolencesdf wrote:Windows doesn't recognize it.
cheers
afx
cheers
Regards, Dan
