I've been using PSP since decades, currently I'm using the latest PSP X5.
When I open a .jpg/.jpeg file and without changing anything on picture hit File-->Save or CTRL-S or the Floppy on the Toolbar, any picture is overwritten with a certain compression factor of about 15 (but not exactly). If I go over the File-->Save As..or F12 function, I can choose the compression factor as I want (f.ex. 5) over the options, it will be retained forever, until I change it manually, what is perfectly ok.
I'm quite sure, it wasn't always like this, but since some versions it is. I think earlier the factor I choose on "Save As..." was also used for "Save". But a mystical compression factor is used, which can't be reproduced manually: 15 is a notch bigger but about the closest.
Question:
Can I set the default compression factor somewhere, I don't want to make the whole procedure over "Save As..." every time, I just want to open an image, edit and click "Save" with a compression factor of let's say 5. Anything for achieving that is acceptable, like modifiying Registry settings or editing config files to the HEX Level. A lot of googling and searching in settings didn't solve my problem yet.
I use very many features of this great program and plugins and stuff, but it turns out, the only problem I have with it, is about the most basic function
