database disk image is malformed
Bugs & Suggestions
imhotep
operating_system: Linux
System_Drive: N/A
Post by imhotep »
Hi Folks,
I have an issue with the After Shot Library Import. I just want to import fotos to a library. Any time I start the import the system freezes.
It says:
Code: Select all
101.485: database disk image is malformed Der Datensatz konnte nicht abgeholt werden
101.485: Scanning file  "/home/karsten/Pictures/Bilder/Sport/Fluggeraete/duxford0362.jpg"
101.518: Importing: "/home/karsten/Pictures/Bilder/Sport/Fluggeraete/duxford0362.jpg"
101.551: Found XMP for /home/karsten/Pictures/Bilder/Sport/Fluggeraete/duxford0362.jpg with 1 versions
101.566: INSERT INTO Thumb  VALUES( NULL,0,? )
101.566: database disk image is malformed Der Datensatz konnte nicht abgeholt werden
101.566: Scanning file  "/home/karsten/Pictures/Bilder/Sport/Fluggeraete/duxford0390.jpg"
101.583: Importing: "/home/karsten/Pictures/Bilder/Sport/Fluggeraete/duxford0390.jpg"
101.606: Found XMP for /home/karsten/Pictures/Bilder/Sport/Fluggeraete/duxford0390.jpg with 1 versions
101.621: INSERT INTO Thumb  VALUES( NULL,0,? )
101.621: database disk image is malformed Der Datensatz konnte nicht abgeholt werden
The entire library is affected. Once I klick on a section within the library tree that contains files, the application freezes. It seems that not a single file is accessible for the library anymore.
I tried to remove the files that are mentioned in the logfile but it doesn't help. It's an endless story.
On the other hand, the entire folder ist OK in File System Mode. All files are accessible.
Any idea how to solve this issue?
afx
System_Drive: N/A
Video Card: FirePro 4900
Re: database disk image is malformed
Post by afx »
Nuke the database and create a new one.
Switch off default preview generation.
Import in small chunks.
cheers
afx
