- How to change the TImeline to the correct # of Frames (in conjunction with "Settings --> Enable 50/60p editing" option is the combination with "Settings --> Project Properties --> Edit --> Corel VideoStudio --> TV Standard" and "Settings --> Project Properties --> Edit --> General --> Frame rate" where depending on your combination can get frame accurate timeline at 24, 25, 30, 50, and 60 fps.
- How to Create a Movie Template using a sample file 1080/50p to create a profile with a data rate such as 26000kbps
So I can import, edit and output any combination of frame rates as a file.
My Questions: What I can not work out is under the Create Disk option to select (or use Disk Template to create) a Profile for:
- Blu-Ray at 23.796/24p profile
- AVCHD 50p profile (note: I know there is no BD 50p std but AVCHD Ver 2 supports this 50p and VS allows you to select to burn to media but only seems to do AVCHD Ver 1 for writing).
In both cases the Frame Type only shows "UFF" and "LFF" and no "Frame" option & the Frame Rate is greyed out.
Nathan
