Why are some JPEGs not visible to ASP?
Bugs & Suggestions
Centauri27
processor: Core i5
ram: 4GB
Hard_Drive_Capacity: 250GB
Monitor/Display Make & Model: Lenovo ThinkPad T410s display
Post by Centauri27 »
I have some panorama JPEGs created by Microsoft Image Composite Editor (ICE). These appear to be normal JPEGs as far as I can tell, but ASP will not display them when I browse to the folder. I've even tried resaving the JPEGs using Windows Paint and Photoshop Elements, hoping that might use a format friendlier to ASP--but no luck. Each of the individual images that make up the panorama display in ASP.
Does anyone have any ideas? Are there certain JPEGs that ASP can't show?
Thanks.
Carl
afx
operating_system: Linux
System_Drive: N/A
Video Card: FirePro 4900
Re: Why are some JPEGs not visible to ASP?
Post by afx »
Probably to large, the limit is 50MP.
cheers
afx
Centauri27
processor: Core i5
ram: 4GB
No, that's not the case because the JPEG is only 6 MB.
afx
System_Drive: N/A
Post by afx »
Centauri27 wrote:No, that's not the case because the JPEG is only 6 MB.
Hmm,
even 6MB can be over 50MP when the compression rate is high enough...
Can you run exiftool over the image and attach the output here?
cheers
afx
Centauri27
processor: Core i5
ram: 4GB
afx wrote: Hmm,
cheers
afx
Here's the weird thing--not only will ASP not import the image, it doesn't even display it in File System view! Therefore, I'm not even able to run the Exif Viewer over it. (Is that the tool you're referring to? It doesn't seem to show the uncompressed size--just the JPEG dimensions.)
Also, is the 50MB limit in ASP the uncompressed size?
afx
System_Drive: N/A
Post by afx »
50MP, not 50MB.....
exiftool is mit part of AS, just Google it.
cherrs
afx
Centauri27
processor: Core i5
ram: 4GB
I did some more testing using a very wide panorama. After saving a number of panorama JPEGs, it would appear that ASP will display the file only when the photo width is less than 10100px. Odd boundary though. At that level, the uncompressed size of the photo is just under 30MB. Attempts to create panos wider than 10100px (but still under 50MB uncompressed) results in them not being displayed.
afx
System_Drive: N/A
Post by afx »
I think Corel documents the dimension limit somewhere on the specs pages, but I can't remember them.
cheers
afx
Trucks
System_Drive: N/A
motherboard: 64bit
processor: quad
ram: 3GB
Video Card: Nvidia
sound_card: onboard
Hard_Drive_Capacity: 2TB
Monitor/Display Make & Model: Eizo S2243 W
Post by Trucks »
Can`t find them anymore.
Trucks
dondean
ram: 48GB
Hard_Drive_Capacity: 1T+.5T SSD
Corel programs: PSP 2020, 2019, 2018, X9, X8
Post by dondean »
I ran into the same problem with size, Carl.
I experimented with numerous sizes and found that as soon as a photo was larger than 40Mpix (that's pixels, not file size), it would not show up in the Catalog nor the file view. I did not run into a maximum file size (MB) limit, although there might be one.
I could not find this information anywhere, either online on in the user's manual.
{Lightroom supports photos up to 65,000 pixels long or wide, or up to 512 megapixels, whichever is smaller.}
Don't know about the other manufacturers, but about half of the Nikon DX and FX cameras now have 24MP or larger sensors, so if you wanted to stitch together just two of these photos, you'd likely run over the 40Mpix limit.
I hope Corel will increase the ASP Mpix limit in their next release, as it is way behind LR.
