Dear all,
does someone experience the same issue. that ASP, when opened and directed to a folder with ~ 275 JPG images (from a Panasonic TZ5), starts creating the thumbs and crashes after some time.
Same behaviour when exporting modified JPGs ... after 130 from 275 images ASP crashes.
This behaviour did not occur with the provious version.
Just tired again to export the above mentioned JPGs and after image 65 I receive a strange error popup (for the first time):
MS Visual C++ Runtime Library
R6025
- pure virtual function call
I posted a bugreport at the monkey - however their file uploader link seems to be broken.
Best regards
Reinhold
V 1.2.07: ASP crash when doing nothing
Trucks
- System_Drive: N/A
- motherboard: 64bit
- processor: quad
- ram: 3GB
- Video Card: Nvidia
- sound_card: onboard
- Hard_Drive_Capacity: 2TB
- Monitor/Display Make & Model: Eizo S2243 W
Re: V 1.2.07: ASP crash when doing nothing
- Clear the Cache
Me helps to turn OpenCL on and off. Sometimes it must be on sometimes off. Sometimes i had too turn up the OpenCL Level up and down. No fix, but if you need the pics...
Regards
Trucks
- Clear the Cache
Regards
Trucks
rgraf
- processor: Intel I7
Thanks Trucks,
cleared the cache but it didn't help much, besides ASP did not already crash during thumbs creation
Either switching OpenCL on or off, ASP however crashed when I export the 275 images.
To cross check, I also deactivated all addins via the addin manager and restarted ASP, but it didn't help either.
There is nothing special with these images ... just simple JPGs and my hardware should fit all the needs with Intel I7, 16G RAM, Win7/64Bit, etc.
Regards
Reinhold
Regards
Reinhold
afx
- System_Drive: N/A
- Video Card: FirePro 4900
Yesterday I was interrupted while culling images. AS sat idle for at least 10 minutes.
When I finally returned to AS I just tried to switch to a new Image which resulted in a non-responsive AS.
cheers
afx
cheers
afx
Could you explain how to clear the Cache manually please?Trucks wrote:Hi,
- Clear the Cache
Regards
Trucks
Thanks,
Vinny
Trucks
- System_Drive: N/A
- processor: quad
- ram: 3GB
i can only tell under Linux its in the home/yourname/.AfterShotpro Folder. Delete the cache Folder.
Regards
Trucks
Regards
Trucks
Trucks wrote:Hi,
Regards
Trucks
Thanks Trucks,
I am wondering where is the folder located in windows?
Thanks,
Vinny
Trucks
- System_Drive: N/A
- processor: quad
- ram: 3GB
C:/User/?
C:/Programs/?
I dont think there are two Folders with AfterShotPro/Cache.
Regards
Trucks
C:/Programs/?
Regards
Trucks
afx
- System_Drive: N/A
Check Help->System InfoVinny wrote:I am wondering where is the folder located in windows?
The cache is in the user home directory.
cheers
afx
gregglee
- motherboard: Asus Sabertooth 990FX R2.0
- processor: AMD FX-8350 8core 4600 MHz
- Video Card: nvidia GTX 660ti
- sound_card: on board
- Hard_Drive_Capacity: 10 TB
- Monitor/Display Make & Model: viewsonic vb2365WB + LG 1933TR
I was getting frequent freezes (not responding) while editing rapidly though several images. I found that PS CC had installed a startup program creativecloud.exe that continued to run all the time. After I killed the process the freezes stopped. (I then disabled the autostart.)
Could be some other process interfering as well.
