adding or changing music files
I have PS3 boxed version and completed about 60 slides , when I play the slides on my computer , i only get this one song file which repeates over and over. I read some past posts that say go to " advanced audio settings" I can not find that file ?
I am trying to create a VCD file not a DVD file . Is that the problem ? Thank you
Rick Fredrickson from Northern California
Telgaladhion_Greyskye
you can find the "advanced audio settings" on the 'Slideshow Tab' on step two - 'Theme'. here you can select the music file that you want played when viewing your slideshows, or you can click mute. if you want your music to end simultaneously with your slideshows, click the 'Match slideshow to audio duration' provided your audio is longer than your slideshows. hope this helps.
2log
re: adding or changing music files
Like Telgaladhion_Greyskye said, you can go to the advanced audio settings and add more than one music there. Just drag the music clip to the particular slide you want it to start...
Go to http://www.ulead.com/learning/dps.htm for more PictureShow tutorials.
