Can MovieFactory record 6 hours to single sided DVD?
bruscol
I have a Media Center PC running Windows MCE 2005. I have various programs recorded, in various qualities of recording. Can I record any of them to DVD to hold 6 hours per DVD? I have a TiVo Based Unit with Burner and it handles 6 hours of programs without problem. The question is can MovieFactory and Win MCE 2005??? Thanks.
Lou
Lou
keithm
It depends what you want to play the DVD on. I don't think most set top players will play a 6 hour single layer dvd (the bitrate is too low). There are other options but they won't always play on a standard player.
I think the most I have got is 2.5 hours, if the bitrate dropped below 3000 kbs my players wouldn't load the DVD.
There is X-DVD (don't know the spec and support) and C-DVD (chinese DVD) or even divx but again it depends on what you wnt it to play on
heinz-oz
Heinz, since it is within DVD Specs (mpeg-1, 352x240 or 352x288 NTSC/PAL, CBR up to 1856kbps, audio has to be 48khz), I think as long as the DVD Player can play home made DVD's, it should be able to play a dvd with these specs.
In fact, I've seen several standalone DVD recorders go to these settings (or similar) when recording in a 6-hour mode (onto DVD discs).
George
heinz-oz
not only have I seen it, I have done it
I don't go for the full 6-hours. I prefer to use 1856kbps video bitrate when using mpeg1 (that's the highest bitrate allowed for mpeg1 for DVD Video). In fact, if you have the "Do not convert compliant mpeg files" option checked in MF3 or 4, load in a test mpeg1 video with the specs I listed, and you will see that it does not re-encode them (because they are DVD Compliant). But if you encode 1 bit higher (say 1857kbps), you will see that the video gets re-encoded...
George
cablehead
maddrummer3301
George,
Isn't the mpeg1 spec frame-based?
That's neat to know because one can add a nice slideshow to a dvd
without using up to much room.
The VCD slideshow's I've made are pretty good considering the low
bit-rate. Actually they look great. The frame-size is a little small though
on the TV. So if the quality of the source pictures are good then the
slideshow should be adequate considering the low bit-rate.
My panasonic dvd recorder has a 8 hour recording mode.
Never tried it.
The 6 or 8 hour modes?
Maybe they are good for surveillance work ( or soap operas).
MD
Never tried it.
MD
bruscol
Burning 6 hours of MCE Recorded TV Programs to DVD
The main reason I ask is that it is quite easy with my TiVo unit with built in DVD Burner - I am able to record to 6 hours without a problem - it takes less than an hour to burn a 6 hour DVD - have played it in my oldest DVD player without a problem - did not realize it would be such a hassle with a Windows machine - but I guess I should have expected that anything Windows based would come up short against a Linux-based TiVo unit.
At this point - if someone came up with a dual tuner 300 GB Tivo unit with built in burner I would take my HP z545 and use is for target practice. But what mystifies me is why the third party software for an MCE 2005 machine can't do what is childs play for a Linux machine.
Any suggestions as to software that would easily burn to 6 hours to one DVD without having to worry about bit-rates, etc- would be much appreciated.
Lou
Lou
maddrummer3301
