Problem with Prodad Rotopen
gary1988
- motherboard: Intel LA-6901P
- processor: Intel Core i5-2450M
- ram: 6GB
- Video Card: Intel HD Graphics
- Hard_Drive_Capacity: 680GB
- Monitor/Display Make & Model: Acer 5750
I have edited a map and a train image which is fine when applied and the preview works fine but as soon as I create the rendered video the path and the train image have moved to a position further down the map, and I have no idea how to see the path and train image in the right place. Are there any fixes???
Kingston
- motherboard: Gateway [Acer] DX4860
- processor: Intel Core i5 3rd gen. 3 GHz
- ram: 8 GB
- Video Card: Intel HD 2500
- sound_card: Bluetooth
- Hard_Drive_Capacity: 1 TB
- Monitor/Display Make & Model: Dell ST2210; Samsung SmartTV 3D 40"
Re: Problem with Prodad Rotopen
You will have to match the frame size and aspect ratio of the project properties with a share preset. If they don't match, the RotoPen path won't be where you expect it to be. By default the project properties are 720 x 480 with a 16:9 aspect ratio. There's a share for DV Widescreen which has the same properties. Unfortunately, once you have used Roto Pen with a particular set of properties, you can't change project settings without throwing the Roto Pen path off-track.
Having just the aspect ratio matching is not enough to keep the path on-track. The frame size needs be the same, probably with a few exceptions.
I would create a standalone HD project just for the RotoPen sequence, and share to a matching share preset. Use the resulting video file in your main project. That way the path won't be disturbed when you upscale or downscale relative to the project properties.
franapo
- System_Drive: N/A
- motherboard: FUJITSU D2990-A3 S26361-D2990-A3
- processor: Intel Core i73770
- ram: 8gb
- Video Card: NVIDIA GeForce GT 630
- Hard_Drive_Capacity: 1000gb
- Monitor/Display Make & Model: Acer H243H
Thanks. That cleared my mind. What are the parameters for a standalone hd project for rotopen and how have we to manage settings?
Hi franapo
Welcome to the forums
I think Kingston is referring to setting the project properties to match your video files frame size.
So if HD your video is probably 1920 x 1080
Video Studio by default uses standard definition sizes, however we can manually change by editing the project properties to Avi similar to:-
NTSC non-drop frame (30 fps)
Microsoft AVI files
8 bits, 1920 x 1080, 30 fps (use 25 for Pal)
Upper Field First
Microsoft Video 1
15 Key frame rate:, 75% Quality
PCM, 44.100 kHz, 16 Bit, Stereo
I am sure Kingston will clarify
Microsoft AVI files
Upper Field First
Microsoft Video 1
franapo
- System_Drive: N/A
- ram: 8gb
Hallo! Great! I started a new project setting avi 1920x1080. Then created a new video file blu-ray with my map rotopenned.
Inserted in my big video file and rendered. Great!
