Version 1.2.0.7 is out
acmh
- System_Drive: N/A
- motherboard: Asus P6T Deluxe V2
- processor: i7-920
- ram: 6 GB
- Video Card: Nvidia Geforce N9500GT
- sound_card: M-Audio Delta Audiophile 2496
- Hard_Drive_Capacity: 1.5 TB
- Monitor/Display Make & Model: HP LP2475W
Re: Version 1.2.0.7 is out
AFP for Linux 64 installed fast and without any problems on my Kubuntu system. NN License works. And the support for the Ricoh GR makes me think hard about getting one ... well, I still have to wait until I can check the optional viewfinder.
Thanks Corel.
Thanks Corel.
Ianr
- Monitor/Display Make & Model: Dell 30
Wooo Hoooo ... Thanks Corel so much for continuing support of Aftershot Pro .....
Much appreciated indeed !!!!
Have installed the new version, but there still is a problem if you use ztext / zshadow and zframe in the output batch. The process stops and the program locks up. Same problem as with the 2 previous versions
My plugin's is the latest versions from the website.
I will return to the version that works..... 1.0.1
Regards
Per
Regards
Per
gareth
- motherboard: Acer Aspire TC-605
- ram: 12Gb
- Video Card: NVIDIA GeForce GTX 745
- Hard_Drive_Capacity: a few TB
- Monitor/Display Make & Model: AOC 2369M sRGB
Anyone know if it is possible to install this alongside older version in Windows so I can check out all the plugins I use before moving across -- I only have one Windows computer at the moment
ex-Bibble - mostly OLY E-510 and E-M5 + Win 8
afx
- System_Drive: N/A
- Video Card: FirePro 4900
not really doable. I use a VM for such tests....
cheers
afx
cheers
afx
dsigman
- motherboard: ASUS A78M-A
- processor: AMD A8 6600K
- ram: 8 GB
- Video Card: ASUS R7 250X
- sound_card: AMD High Definition
- Hard_Drive_Capacity: 1 TB
jpmccormac
RAW Support for FZ200 Now? NOT.
The patches and Updates page at Corel says ASP now supports my Panasonic FZ200 RAW files (.RW2) but they don't appear in the file list after performing the update.
"All who wander are not lost."
Dutchmm
- System_Drive: N/A
- motherboard: Asus 97
- processor: Intel i7 4785T
- Video Card: Onboard Intel
- sound_card: Intel AC97
- Hard_Drive_Capacity: 2.5TB
- Monitor/Display Make & Model: Philips 28"
- Corel programs: ASP 3 Pro (and 2 and 1 before)
Re: RAW Support for FZ200 Now? NOT.
All the same, a technical examination of the binary shows:jpmccormac wrote:The patches and Updates page at Corel says ASP now supports my Panasonic FZ200 RAW files (.RW2) but they don't appear in the file list after performing the update.
Code: Select all
strings AfterShotPro | grep -i fz200
panasonicfz200.icc
PanasonicDMC-FZ200
?Panasonic DMC-FZ200 Linear (FZ200hVFATB_20X.RW2, ColorChecker)
Panasonic DMC-FZ200-
jpmccormac
-------------------Dutchmm wrote:All the same, a technical examination of the binary shows:jpmccormac wrote:The patches and Updates page at Corel says ASP now supports my Panasonic FZ200 RAW files (.RW2) but they don't appear in the file list after performing the update.
Code: Select all
strings AfterShotPro | grep -i fz200 panasonicfz200.icc PanasonicDMC-FZ200 ?Panasonic DMC-FZ200 Linear (FZ200hVFATB_20X.RW2, ColorChecker) Panasonic DMC-FZ200
Okay, but what does this mean - in plain English? I can right click on a .RW2 file in the Windows 7 file manager and select Open with ASP and it will open the RAW file, but they don't show up in the ASP file system.
Dutchmm
- System_Drive: N/A
What it means - I believe - is that despite the absence of the FZ200 in the release nots, this version can process the .RW2 files the FZ200 produces. You may reasonably ask me how I come to this conclusion? I would base my answer on the difference between the strings that contain "Sony DSLT <something>" in the old and new versions. At a guess, Aftershot looks recognises the camera you used by reference to the Manufacturer and Model strings in the raw file.
jpmccormac
The FZ200 IS mentioned as being supported in the release notes on this page - http://www.corel.com/corel/pages/index. ... gid=800161
Dutchmm wrote:What it means - I believe - is that despite the absence of the FZ200 in the release notes, this version can process the .RW2 files the FZ200 produces.
jpmccormac
Thanks. I'll give it a try. In the meantime I'll stick with ACDSee Pro 6 which has no problem with the .RW2 files.Trucks wrote:i think you should feed the monkey. https://www.surveymonkey.com/s/ASPFeedback
Moldmaker
- System_Drive: N/A
- motherboard: ASRock X58
- processor: Intel i7 950 3.07 GHz
- ram: 6GB
- Video Card: NVidia GTX 580
- sound_card: Onboard
- Hard_Drive_Capacity: 1TB
- Monitor/Display Make & Model: Samsung 2233 RZ
Hey, that's my impression too, but I thought I might be imagining it ...dsigman wrote:I have the impression that it runs faster than the previous version,
Mm.
malepo
- System_Drive: N/A
- processor: Intel
- sound_card: Intel
- Hard_Drive_Capacity: 690GB
- Monitor/Display Make & Model: acer
- Corel programs: AS1, AS2, PSPX8
I second that impressionMoldmaker wrote:Hey, that's my impression too, but I thought I might be imagining it ...dsigman wrote:I have the impression that it runs faster than the previous version,
Mm.
