Version 1.2.07 broken for Canon 550D
Bugs & Suggestions
rhadamanthys
operating_system: Linux
System_Drive: Z
processor: i5-3470
Video Card: Nvidia
Hard_Drive_Capacity: 2TB
Monitor/Display Make & Model: DELL 2560x1440
Post by rhadamanthys »
Hello,
I just downloaded Version 1.2.07, now I can handle my Canon 6D files :D , but my Canon 550D files which where working before the upgrade are just a pattern from white an violet. You can see the preview for a short time, and the the preview and the picture in the main view change to unusable. :evil:
Screenshot of a directory with Canon 6D and Canon 550D files
afx
System_Drive: N/A
Video Card: FirePro 4900
Re: Version 1.2.07 broken for Canon 550D
Post by afx »
Was that messup freshly rendered or from the cache?
I fear it was freshly rendered from your description ;-(
But just in case it wasn't, nuke the cache and then check again.
(to quote Bernd: The 11th Commandment: Thou shall delete the cache before running new versions)
cheers
afx
rhadamanthys
System_Drive: Z
processor: i5-3470
Video Card: Nvidia
afx wrote:Was that messup freshly rendered or from the cache?
cheers
afx
Even if I mount the SD-card direct I get the same effect.
rhadamanthys
Trucks
System_Drive: N/A
motherboard: 64bit
processor: quad
ram: 3GB
Video Card: Nvidia
sound_card: onboard
Monitor/Display Make & Model: Eizo S2243 W
Post by Trucks »
- did you nuke the cache (under Linux in your Home Folder .AfterShotPro/cache)?
- in the Cam and other programs the Pic look ok?
Regards
Trucks
grubernd
System_Drive: N/A
Post by grubernd »
very similar bug also with Canon 5D Mk2 (worked before) and 1D X (new camera).
edit: added screenshots.
Reason: added screenshots.
Bibble since 2004. Aftershot until 2020. From then on darktable.
greerd
System_Drive: Z
processor: Intel i7 920
ram: 12 GiB
Video Card: nVidia GeForce 260
sound_card: Onboard
Hard_Drive_Capacity: 5 TB
Monitor/Display Make & Model: Dell UltraSharp U2410
Post by greerd »
I had a problem somewhat like this, and it turned out to be a plugin. Try disabling all plugins and see what happens.
grubernd
System_Drive: N/A
Post by grubernd »
weird stuff.
removing all plugins, adding back, several times, cured the 5D2 files (for now).
but the 1Dx is still and permanently broken.
SteveCase
System_Drive: N/A
motherboard: ASRock 990FX Extreme4
processor: AMD FX-8350
ram: 16.0 GB
Video Card: GTX 550ti
Post by SteveCase »
for the 1D screenshot if this was Capture 1.... I would have suggested turning off openCL
Steve in Seattle,WA
grubernd
System_Drive: N/A
Post by grubernd »
SteveCase wrote:for the 1D screenshot if this was Capture 1.... I would have suggested turning off openCL
both screenshots are from Aftershot. openCL doesnt work on my machines, so it was off anyway.
rhadamanthys
System_Drive: Z
processor: i5-3470
Video Card: Nvidia
Nuking the cache helped. The strange thing was, even reading direct from SD card didn't work, there was no cache for this images.
rhadamanthys
System_Drive: Z
processor: i5-3470
Video Card: Nvidia
In a directory with Canon 6D and Canon 550D files, I can nuke the cache every day because at some point the effect pops up.
rhadamanthys
