Video Studio Pro X6 - Screen Capture Will Not Work
kevsim
motherboard: Intel - D865GLC
processor: Pentium 4 -2.6GHz
ram: 3GB
Video Card: GForce2 MX 400
sound_card: Creative EMU10K1
Hard_Drive_Capacity: 660GB
Monitor/Display Make & Model: ASUS VW222
Post by kevsim »
I am using Video Studio X6 trial and the Screen Capture feature does not work.
The capture window opens but the Capture Button is grayed out along with the Sound Source button.
I am running this on an XP SP3 system with -
4 GB memory
2.66 Ghz dual core processor
I would appreciate any information.
Is there any information available as to what requirements my system may not have?
All other programmes run OK on the computer.
kevsim
andrewandrew
processor: Intel
ram: 4GB
Hard_Drive_Capacity: 800 GB
Monitor/Display Make & Model: Toshiba 19200 * 1080
Re: Video Studio Pro X6 - Screen Capture Will Not Work
Post by andrewandrew »
Hi, I just saw your post, I am also using Video Studio Pro x6 Ultimate and I want to use the screen capture feature. I have tried it in standalone mode and also launched from the video editor and the result is the same. The screen capture program starts up but the red record button is not selectable, and I also cannot enable audio recording from the settings.
I have tried this now on a high end system and I get the same result. Its not a system requirement issue, it must be a settings issue in a config file. I have the Pro X6 ultimate so it is nothing to do with it being a trial either. This is all I know right now will see what else I can find out
Can anyone point me to a solution so I can use this
Many Thanks
regards
tania
operating_system: Vista Ultimate
ram: 6gb
Hard_Drive_Capacity: 1TB
Post by tania »
Good Morning
I am having the same problem too with the capture, the record buttons are not selected.
This is a important part of the package, need help urgently please
T.H
andrewandrew
processor: Intel
ram: 4GB
Hi, judging from almost 150 clicks on this topic this is occurring to other folk, I am on a vista system, so too are the previous posters is anyone on a windows 7 or windows 8 with the same issuer?
Really need an answer to this, I am in a tight time bind
many thanks
Hi Andrew
Just saw this post
Sorry you are having problems with the Screen Capture, and no I don’t remember this being raised before
The OP was using Windows XP and others Vista so don’t think it is an Operating System issue.
Did you install the program using Administrator rights?
I used both XP and now W7 without problems.
When you start Video Studio right click the icon and “Run as Administrator”
As a thought, are you using multiple monitors?
I really don’t know what to suggest other than re-installing the program, however I don’t think it will be an install issue for all of you
Regards Trevor Andrew
mgrogan
motherboard: ASUSTeK COMPUTER INC. P8B75-M Rev X.0x
processor: 3.60 gigahertz Intel Core i75-4790
Video Card: NVIDIA GeForce GTX 650 Ti BOOST
sound_card: NVIDIA S27C350-4
Hard_Drive_Capacity: 2 TB
Monitor/Display Make & Model: Samsung 27" Series 3 LED MSC350_S27C350H
Corel programs: VideoStudio Ultimate 2019
Post by mgrogan »
I am unable to get X6 Pro to record my system audio.
The Recording options does not show to me which device I should select.
Can anyone help me please?
Margaret
Oops
corel vs x6 capture 02 device mgr2.jpg (16.72 KiB) Viewed 10564 times
Corel VideoStudio Pro X6, Win 8 .1Pro 64 bit, i5-3470 CPU @ 3.2 Ghz, 8 Gb Ram,
Post by BrianCee »
Have you chopped the bottom of that window off - where's your sound card/audio system icons ?
mgrogan
Post by mgrogan »
BrianCee wrote:Have you chopped the bottom of that window off - where's your sound card/audio system icons ?
Oops, yes I had trying to make it a small file :(
Margaret
corel vs x6 capture 02 device mgr2.jpg (16.72 KiB) Viewed 10563 times
Right click the Recording tab window for Show Disconnected devices, there should be other options, maybe Stereo Mix
This may depend on your audio driver as to what is available.
mgrogan
Post by mgrogan »
lata wrote:Right click the Recording tab window for Show Disconnected devices, there should be other options, maybe Stereo Mix
No option for Stereo Mix
lata wrote:This may depend on your audio driver as to what is available.
Is it one of these that I need to check?
Belarc for
Multimedia:
High Definition Audio Device
NVIDIA High Definition Audio
NVIDIA Virtual Audio Device (Wave Extensible) (WDM)
Pro 9000
Other devices:
Digital Audio (HDMI) (High Definition Audio Device)
S27C350-4 (NVIDIA High Definition Audio)
Device Manager
corel vs x6 capture 02 device mgr2.jpg (16.72 KiB) Viewed 10532 times
I checked that the drivers for each of these were updated.
Margaret
RobertOZ
Hard_Drive_Capacity: 7 TB
Post by RobertOZ »
Hi Margaret,
The following Microsoft link may give you some pointers on how to obtain Stereo Mix or Wave Out
http://answers.microsoft.com/en-us/surf ... b209024009
Robert
