Check original image
estima
operating_system: Linux
Hard_Drive_Capacity: Lisboa500G
Post by estima »
Hello,
Is there a way to quickly access the original image in AfterShot Pro? I find it useful to check the original image during the editing process.
Currently, the only way I know is not very practical: press CTR + SHIFT + R (reset image) and after checking I use Undo.
I find it strange that tere is no shortcut to this function.
Am I missing something?
afx
System_Drive: N/A
Video Card: FirePro 4900
Re: Check original image
Post by afx »
You could use the history.
Or create a version for side by side comparison.
cheers
afx
estima
Post by estima »
The problem with the history is that it is not kept between different machines. Example: edit an image in the laptop and then transfer the files to the PC and open them there. The history is gone.
The solution of using a second conversion using the defaults is not practical at all. It imples switching between two images which involves multiple clicks.
I find it strange that no one has this problem...
afx
System_Drive: N/A
Post by afx »
estima wrote:The problem with the history is that it is not kept between different machines. Example: edit an image in the laptop and then transfer the files to the PC and open them there. The history is gone.
Thankfully yes, why would I want a gazillion editing steps to pollute the XMP file?
Why switch? Multiview, that is where the version comparison is most useful.
Because people have a different working style.
There is usually not much need to see the original. More important are intermediate steps in the process.
cheers
afx
tintin
processor: Ryzen R5 3600X
Post by tintin »
...you can simply use Ctrl+R for checking the original image and Ctrl+Z to make it then undone.
... this you can repaet s long as you want ;-)
br
tintin
my plugins on the official plugins homepage
If you find my plugins helpful, please make a donation to support further developments - just click here, thank you!
tundraquad
System_Drive: N/A
Post by tundraquad »
as afx says,
creating a version, and toggle the [M] key for side by side comparison is very practical. Moreover, I think it's the safest method (who knows what may happen with your computer just before you hit Ctrl+Z).
So long.
