PSP X5 Transparency/mask problems
yukonzoom
Post by yukonzoom »
:( I cant find any info on this anywhere, but i am having a problem with the mask automatically deleting and making transparent the image when I load up a TGA. Simply deleting the mask doesn't bring back the parts of the image that are become transparent, the mask is deleting everything it touches upon loading of the image. Is this a setting somewhere I accidentally turned on? or a bug? PSP didn't used to do this when I first installed it. I have reset all the preferences, uninstalled/reinstalled, but no fix.
This is what I am getting in PSP:
What the image SHOULD look like (opened in PS)
Michu
Re: PSP X5 Transparency/mask problems
Post by Michu »
Had a similiar issues with GIMP and certain TGA files. The cure was a workaround - decompose an TGA file into RGB (ending up with 2 channels - Grey & alpha) and recombine it from RGB again - I would get original image back minus transparency,, which I'd have redo.
It looks like both GIMP and newer PSP have some issues with TGA files saved in PS......
yukonzoom
Post by yukonzoom »
Apparently this is still a problem in X7. Is there a setting somewhere so the alpha isn't auto transparencing the image?
