I've just completed my first project and when I attempt to create a video file for hard disk output I'm unsure what option I should select from the drop down box that gives me the highest quality without re-rendering the video.
My AVCHD 50p original files are according to the file properties in VSP -
PAL HDMV
H.264 Video
24bits, 1920/1080, 16.9
50.000 frames/sec
Variable bit rate (max.26000 kbps)
Dolby Digital Audio
48000 Hz, 5.1 channels 384 kbps
So it looks like I need to select AVCHD 1920x1080 50p however in the properties for that file creation, the video bitrate is max 20000 kbps (my video 24.7) and audio is only 2.0 (my audio 5.1).
I really would like to retain the 5.1 audio and my higher video bitrate.
Also when I view the project properties the video is shown as 1024 x 576.
PAL double (50 fps)
Microsoft AVI files
24 bits, 1024 x 576, 50 fps
Frame-based
Uncompressed
PCM, 48.000 kHz, 16 bits, 5.1 Channels
Any tips on how I should proceed would be appreciated.
Thanks.
VSP X6 first project output settings
Re: VSP X6 first project output settings
Make sure the first clip in the timeline is one of your 50fps video files.
Share Create Video File -- Same as First Video Clip, should create a video file using the same settings suitable to playback on pc or TV via USB stick.
You should also be able to create your own template, make Movie Templates Manager using the ADD option
Hope this helps
Hope this helps
