Hallo,
I have hundreds of paper based photos, damaged in color disperse caused by a flood in our basement. I cleaned and dried them all, and I made a digital copy with my mobile phone camera. I'm using PSP X5 to resize the photos and I used "intelligent correction" from PSP. Result of copy is now better than the original, but the color disperse is still there and I have no idea, if there is a way to reduce this damage with PSP (see the blue colored areas in uploaded sample picture ).
hfrsamba
PSP X5 - retouch of photos with color disperse failures
hfrsamba
- motherboard: AsRock B85M-ITX
- processor: Intel Pentium Dual-Core
- ram: 8 GB
- Video Card: Intel onboard
- sound_card: Realtek
- Hard_Drive_Capacity: 2000 GB
- Monitor/Display Make & Model: Samsung SyncMonitor S24B150 24 inch monitor
using Paint Shop Pro X, XI, X5, VideoStudio X5 Pro, Adobe Photoshop Elements 8/9/11 on Windows 7
using VideoStudio X7 Pro on Windows 8.1
Joelle
- motherboard: Asus Prime B350M-A
- processor: AMD Ryzen 5 1500 Quad-Core
- ram: 16 GB RAM
- Video Card: NVidia GeForce GTX 1050
- Hard_Drive_Capacity: 1TB
- Corel programs: PaintShop Pro X9
Re: PSP X5 - retouch of photos with color disperse failures
Adjust>Color>Fade Correction is a good place to start.
As for the the blue stripes, using the Clone Tool might help in one or two instances, but unfortunately it will be almost impossible to correct.
I would also suggest using a scanner instead of a telephone camera.
Scan at a high resolution for more detail, it will make retouching a lot easier.
Joëlle
Joëlle
Joëlle
(PSPX9 )
(PSPX9 )
hfrsamba
- ram: 8 GB
Joëlle,
thank you for this hint. My telephone camera uses a resolution of 1360x1848 Pixel, 72x72dpi. My "old" scanner can gives on standard 99x99dpi up to 600x600dpi . It was also a lot of work to make 700 and more photos of all pictures with camera and with scanner it is a lot of more work, because I always have to put in the photo, make several steps on computer to select scanner, make a scan, wait more time than a click and than put in the next picture (needs at all the 10th multiple work). I think this can only be done for some few pictures.
"Adjust>Color>Fade Correction" I will try. If there are good results, I also will try it with a picture from scanner. I will agree, completely I cannot correct the failures, but a little bit better quality would be nice.
Could you please translate "Fade Correction" to german (something like "verblassen"), so I can find it in my german PSP X5 menues
hfrsamba
hfrsamba
Kathy_9
- Hard_Drive_Capacity: 2TB
Google will translate for you. Fade Correction = verblassen Korrektur. It's under Adjust -> Color -> Fade Correction.
hfrsamba
- ram: 8 GB
Kathy_9,
thank you, that gives me much better photos.
...And with a modest use of the cloning tool (I wasn't sure what the big coloured blob in the left of screen, about half way down, was supposed to be, so I left it):
- Attachments
- img1371630725233b-clone.jpg (69.13 KiB) Viewed 4733 times
hfrsamba
- ram: 8 GB
ok, very well.
the big coloured blob in the left of screen, about half way down was not supposed, it is also an color canceling through dirty water.
