Does anyone know how to add/change/delete the menu items that appear in the drop down menus in the library? I see how you can add a new folder for Titles but not for the Transitions or Effects. Also, is there any way to change which filters appear for a particular menu selection?
Thanks,
Tommy
Is it Possible to Customize the Library Drop-Down Menus?
Re: Is it Possible to Customize the Library Drop-Down Menus?
for the transitions you can have the "My favorites" library in which you can have just your favourites showing but there is no way to add library pages for the effects.
Thanks Brian,
That's too bad. There must be a Videostudio file that contains the menu structure info in it, but which one it is and, of course, whether it's editable is another story.
Tommy
Tommy
If I remember correctly from past experimentation the content of the libraries is held in a .dat file somewhere in the VideoStudio programme folder - but I would expect that details about which libraries to show must be buried in an .ini file - not the easiest things for most people to edit - you could upset the whole programme.
