Masks confuse the H out of me. I suppose the jargon doesn't gel with my imgination, or I am just dim?
I have an image, whose outline is well defined, which I am preparing for laser cutting/engraving. I am trying to find a quick and easy way of creating a cutting path around the edges of the image. Tracing in Corel Draw is not good enough. PhotoPaint will convert the mask to a path but it is not well defined. I can easily create an accurate mask with Paint Shop Pro, and even fill it with black colour, but that is as far as I can get. I have tried pasting as a new image but there is an undeleteable and unmoveable layer created which stops the image being visible. Instead of crisp black image I just get a blank white square.
Is there a way, which is easily understood by a frustrated idiot, to convert a mask into an image?
I feel sure that it should be possible but I'm damned if I can see it. Assistance would be very much appreciated.
Save Mask As Image
JayOh
- motherboard: Dell Inc. 0UK437
- processor: 2.00 gigahertz Intel Core2 Duo
- ram: 4gb
- Video Card: NVIDIA GeForce 8600M GT [Display adapter]
- sound_card: HDAUDIO
- Hard_Drive_Capacity: 1393.13
- Monitor/Display Make & Model: Generic PnP Monitor (17.2"vis, January 2007)
photodrawken
- ram: 16Gb
- Hard_Drive_Capacity: 324Gb
Re: Save Mask As Image
1. Fill that "Raster 1" layer with white.
2. Right-click on the layer and select Merge...Merge All.
3. Fill the transparent areas in the merged image with black.
Ken
- ram: 6 GB
- Hard_Drive_Capacity: 500GB
- Corel programs: PSP: 8-2023
Slightly longer process, but this grabs the exact data from the Mask layer and turns it into a raster.
In your Layers palette - Select your Mask Layer
Hit Ctrl + A <- Select All
Hit Ctrl + F <- Float Selection
Hit Ctrl + Shift + P <- Promote Selection to Layer
Hit Ctrl + D <- Select None
You should now have a graphical representation of your mask on its own raster layer.
You can then copy and paste as its own image. Or just save as a JPG and it'll flatten everything on its own.
JayOh
- ram: 4gb
That worked a treat. I thought it could do it but I'm damned if I could fathom it from the distructions.
Anyway, mask sorted and into Corel Draw, traced and outlined. Done job
Thanks very much Ken
photodrawken
- ram: 16Gb
Glad to help.
Ken
