Flood Fill with own colour
Ken Veal
motherboard: msi mpg z390 gaming edge ac lga 1151 ddr4
processor: 360 gigahertz Intel Core i9 900K
ram: 32 GB
Video Card: EVGA GeForceGTX 760 2GB GDDR5 PCI E 3 0
Hard_Drive_Capacity: 1250GB SSD
Monitor/Display Make & Model: Samsung U28E90 28” UHD 4k
Corel programs: PaintSPro2021Ult.PhotoMirage.VS.2020 Ult
Post by Ken Veal »
When I want to flood fill -say a cloudy sky with blue, is it possible to use my own colour-that is an image taken of a blue sky instead of using one of the options shown after clicking to get the default colour choices in PSPro X
hartpaul
ram: 8 Gb
Hard_Drive_Capacity: 1000 Gb
Re: Flood Fill with own colour
Post by hartpaul »
Select eyedropper tool and left or right click on the area of sky on your second image. You can then flood fill with this color. You may have to select the area of cloudy blue sky that you want to flood fill.
Or you could replace the cloudy sky with a totally different sky.
MarkZ
ram: 8 GB
Hard_Drive_Capacity: 500 GB
Post by MarkZ »
You may want to try color changer instead of flood fill for a more realistic look. Watch out for the tolerance setting.
Mark
Ken Veal
ram: 32 GB
Post by Ken Veal »
Thanks for the replies
This is what I did :-
Dropper Tool To change colour
1 Open 2nd Image 1 with colour to use in it
2 Select dropper tool
3 Position cursor on colour wanted
4 Click on foreground ( or Right click for background)
5 Foreground box changes to colour that was left clicked on
6 Selected flood fill tool
7 Clicked on the cloudy sky
8 Changed most of the clouds to blue but a lot of cloud still there
9 In creased Tolerance from 20 to 50 which then covered most of the
cloud.
10 Still lots of white speckles so I used the clone tool to make sky 100% blue
Your comments on this will be appreciated.
Cant find the colour changer.
hartpaul
ram: 8 Gb
Post by hartpaul »
Color Changer is under Flood Fill tool.
If you are getting lots of dots then may need to change tolerance up to 100 or so.
If it then starts to bleed into unwanted areas, may need to make a freehand selection to limit the areas that get flooded further.
Ken Veal
ram: 32 GB
Post by Ken Veal »
The tool options shown for me from top to bottom are
Pan, pick, selection, , crop, drop straighten, red eye, makeover , clone, paintbrush, .
lighten, eraser, background eraser, flood, picture tube, text ,preset shape, pen,
warp brush. oil brush
Kathy_9
Hard_Drive_Capacity: 2TB
Post by Kathy_9 »
You will need to click on the little arrow next to the Flood Fill tool to see the Color Changer tool. Any time you see an arrow next to a tool that means there are other tools nested below the visible tool. Here's a visual.
Click on image for larger size.
Ken Veal
ram: 32 GB
Post by Ken Veal »
As mentioned above, I am using PSPro X and there is no choice for the colour changer or any drop down arrow next to the flood fill tool that I can see
motherboard: Alienware M17xR4
ram: 6 GB
Hard_Drive_Capacity: 500GB
Corel programs: PSP: 8-2023
Post by LeviFiction »
I believe the Color Replacer was introduced in PSP9. So it's in there somewhere.
According to one of my PSPX books it should be on the main toolbar. If you don't see the Color Changer then you should be able to add it from the list of available tools.
Go to the View menu and select View -> Customize.
Under the first tab "Commands" you will see two lists. The one on the left or the first list, is the category, select "Tools" from this list.
The available tools will populate the second list on the right. Look for "Color Changer" in the list. It should hopefully be organized alphabetically so it should be easy to spot.
Click and drag it from right onto the toolbar and it should make the tool available to you.
Ken Veal
ram: 32 GB
Post by Ken Veal »
Thanks for that info,
I went ............... View Menu -Customize- Under Commands Tab then categories -Tools- Select Colour Replacer + drag to Toolbar.
Great! it works
LindaSue
motherboard: Gigabyte
processor: 2.71GHz AMD Athlon II X2 215 processor
ram: 3 GB
Video Card: ATI Radeon HD 4350
sound_card: Realtek AC97 Audio [onboard]
Hard_Drive_Capacity: 1320 GB
Monitor/Display Make & Model: Asus MX279 HDMI 27-inch
Corel programs: Paint Shop Pro X2, X4, X6
Post by LindaSue »
The Color Replacer and the Color Changer are two different tools. The Color Replacer has been around since at least as far back as PSP5. The Color Changer appeared sometime after PSP9. It's there in X2 but I don't know about PSP10 or 11.
Using Paint Shop Pro versions 5, 6, 7, 8, 9, 12, 14, 16
ram: 6 GB
X1 is probably when it was introduced.
Darnit, not sure where I got PSP9 from though I could have sworn that was the box I had seen it on.
I do apologize. Also in the book I was reading I don't know if it's a typo or a title but they were talking about the Color Replacer tool under the heading of Color Changer. So PSPX does not have this amazing tool. Sorry.
