Can't install under 64 bit Linux Mint
Amamba
Post by Amamba »
I get error message: "cannot install libc6:i386".
The 64-bit version seems to be for AMD processors (mine is Intel) and also curses at me.
Any help appreciated !
Trucks
operating_system: Linux
System_Drive: N/A
motherboard: 64bit
processor: quad
ram: 3GB
Video Card: Nvidia
sound_card: onboard
Hard_Drive_Capacity: 2TB
Monitor/Display Make & Model: Eizo S2243 W
Re: Can't install under 64 bit Linux Mint
Post by Trucks »
maybe:
64-bit distributions require 32-bit compatibility libraries (ia32-libs)
from the Corel Homepage.
Regards
Trucks
afx
System_Drive: N/A
Video Card: FirePro 4900
Post by afx »
Amamba wrote:I get error message: "cannot install libc6:i386".
Install the 32bit compatibility libraries.
Nope. 64bit is labeled AMD because AMD implemented that instruction set first...
cheers
afx
Amamba
Post by Amamba »
Trucks wrote:Hi,
maybe:
Regards
Trucks
I must be really slow today. I can't find them on Corel homepage. :oops:
afx
System_Drive: N/A
Post by afx »
The libs come with your distro. Not from Corel...
cheers
afx
shurito
System_Drive: N/A
Post by shurito »
What is the terminal output?
Try after installing:
Code: Select all
sudo apt-get -f install
The missing libs should be installed after that.
If Mint already uses multiarch, you have to activate multiarch in your sources.list
Refer to http://wiki.debian.org/Multiarch/HOWTO
After that, installing the 32-Bit version should work.
