Apply zText watermark to multiple photos at once
AfterShot Pro Plugins
Konzertheld
processor: AMD Athlon II 245e 2.9GHz X2
Post by Konzertheld »
Hello,
it took me a while but I now found and got used to zText as a plugin for watermark creation in ASP. Unfortunately I can't get it to apply to multiple images. I would expect the watermark to appear on all selected images but that does not happen. Is that not possible or am I doing something wrong?
Any help is appreciated. I would also be okay with using a different plugin (Texa was suggested but I couldn't find a compatible version).
afx
operating_system: Linux
System_Drive: N/A
Video Card: FirePro 4900
Re: Apply zText watermark to multiple photos at once
Post by afx »
Copy & Paste,
Preset
or apply a preset in a batch queue
all will work.
cheers
afx
Trucks
System_Drive: N/A
motherboard: 64bit
processor: quad
ram: 3GB
Video Card: Nvidia
sound_card: onboard
Hard_Drive_Capacity: 2TB
Monitor/Display Make & Model: Eizo S2243 W
Post by Trucks »
maybe it dont work when you are in the Multiview Modus "M".
Regards
Trucks
Konzertheld
Thank you both for the replies. Using a preset on export did the trick. I didn't realize I can use plugin settings in a preset.
Do you mark topics as solved somehow in this forum?
Trucks
System_Drive: N/A
motherboard: 64bit
processor: quad
ram: 3GB
Video Card: Nvidia
sound_card: onboard
Post by Trucks »
a) great it works
b) no
Regards
Trucks
afx
System_Drive: N/A
Post by afx »
You could edit the header of the first post and add a [solved]...
cheers
afx
