Cache & settings
FalCT60
Cache & settings
Post by FalCT60 »
Hello,
I have ASP installed on 2 PCs (my main one, plus a laptop running Ubuntu for 2 days now).
Since the beginning, I have been keeping all the settings (plugins, cache, etc.) on the same disk which holds the photos.
To avoid misunderstanding : I have created a folder on to the external disk in which I have copied the data, then I have set the preferences so that the user folder and the catalog are searched to in that location.
This way, whatever can happen, I reinstall and can retrieve my config with zero effort.
When playing with Ubuntu, last day, I went facing a problem that I had never thought about before : the cache was reset by the new installation.
Is there a way to avoid this ?
Thanks in advance,
J.-L.
Trucks
operating_system: Linux
System_Drive: N/A
motherboard: 64bit
processor: quad
ram: 3GB
Video Card: Nvidia
sound_card: onboard
Hard_Drive_Capacity: 2TB
Monitor/Display Make & Model: Eizo S2243 W
Re: Cache & settings
Post by Trucks »
i dont think that this is possible and its realy better. To clean the cache is often the solution of bugs. A new installed system should not use settings from previous installations.
Are the settings in the cache?
Regards
Trucks
FalCT60
Post by FalCT60 »
Hello,
Fortunately, the settings aren't in the cache. But the cache is into the folder where the settings point to.
Having a separate path for the cache would be a good thing IMO. Now that I have played with Ubuntu version, it has totally reset the cache, which means that I'll have to recreate it on the main computer. :?
J.-L.
t3mujin
motherboard: Asus P5QL-E
processor: Core2 Quad CPU Q6600 2.40GHz
Hard_Drive_Capacity: 1 TB
Monitor/Display Make & Model: HP LP2475W
Post by t3mujin »
I have a slightly different option: I have ASP both on my desktop and my travel laptop, I created a folder on Dropbox where I moved some of the folders and files of my ".AfterShotPro": plugins, copysets, presets, hotkeys and custom menus but not the cache folder. Then I created links from these folders from Dropbox to the profile folder of my desktop and laptop, I had zero issues with this setup and have everything I want synced between the two machines.
tundraquad
System_Drive: N/A
Post by tundraquad »
on ASP v1.2.0.7, I am still unable to clean the cache other than deleting the 'cache' folder itself. Holding the Shift key while starting ASP still doesn't work on Linux.
Any feedback?
Thanks in advance.
afx
System_Drive: N/A
Video Card: FirePro 4900
Post by afx »
I guess that SHIFT thingy will never work on Linux, because the startup concept is totally different.
cheers
afx
tundraquad
System_Drive: N/A
Oh I see. Well, that's too bad.
So, the only way is to keep deleting the cache folder manually?
Trucks
System_Drive: N/A
motherboard: 64bit
processor: quad
ram: 3GB
Video Card: Nvidia
sound_card: onboard
Post by Trucks »
Maybe some script would work, as an alternative starter?
Just an Idea.
Regards
Trucks
afx
System_Drive: N/A
Post by afx »
tundraquad wrote:So, the only way is to keep deleting the cache folder manually?
Yup.
Even on Windows, I consider it more reliable anyway.
cheers
afx
tundraquad
System_Drive: N/A
Alwright. Thank you kindly for the info.
Cheers.
