Using paintshop pro x4.
Having been previously used too photoimpact 12 ( i think it was ) just playing around with this pro x4. Not looking for anything special - just more stable programme ( PI 12 kept crashing etc )
In a nutshell, two quick things im sure most will know the answer too.
(A) How do I get a 'type of' list/showcase of all the frames / photo effect / pencil effects / bubbles etc - to show up on the main screen..on the right hand side ( like in PI12 ). I know i can use a dropdown list..but what a job! having to click here and there..when in PI12..all you had to do is...go to the right-hand side, and hover/click over a photo frame for example..and it would show you there and then what your image will look like with the desired photo frame or bubble effect.
I assume its just a simple case of clicking a button to make this viewable menu appear.
(B) I cant seem to blend out the edges of a photo. I know it can be done..nothing exciting..just literally, have a photo and i want to blurr/smear the edges..so that it will blend into the background...or a colour in the background. All i can achieve when clicking on the photoframe is - despite using options of 'create effect on the inside or outside of the frame' etc is that it makes a whopping great white border around the photo and blends in with that!!!
Showcasing PI X4
- hartpaul
- ram: 8 Gb
Re: Showcasing PI X4
(A) Try Effects > Effects Browser
(B) try Layers > Load/Save Mask >Load Mask from Disk and you have a few masks there you can load.
Also you can make and save your own preferred masks for later use.
garjobo
Thanks thats great. Will give that ago. Cheers again for quick reply.
