Elgato footage(MP4) in CVSPX6 :/
BowleyC73
- motherboard: Packard Bell SJV51_DN V2.02
- processor: 2.20 gigahertz AMD Athlon II P340 Dual-Core
- ram: 4GB
- sound_card: ATI HDMI Audio
- Hard_Drive_Capacity: 80.02GB
- Monitor/Display Make & Model: Packard Bell Easy Note TM80 v2.02
I'm a new user and need some help please.
I use Corel VideoStudio Pro X6 and an Elgato GameCapture HD which records videos in an mp4 format. When I try to use my mp4 footage from my elgato it tells me "the file contains no video data." and will not let me insert it. How can I use my mp4 footage in the software?
Any help would be appreciated.
Thanks.
Thanks.
Re: Elgato footage(MP4) in CVSPX6 :/
There must be something a little different about your mp4. Can you download a small freeware program called GSpot and navigate in it to one of your clips. Then tell us all that it says about the video, including frame size and the codec used. Or better still, take a screen shot of the GSPot window and attach it here. Thanks.
have a look at this topic - it is the same as your problem but in X5 - the solution should also work in X6 - read it here :-
http://forum.corel.com/EN/viewtopic.php?f=1&t=50148&
BowleyC73
- ram: 4GB
Thank you, here is the info. Screenshot was too large.
codec: avc1 name: H.264/MPEG-4 AVC
codec status undetermined
frame size: 59.941
frame size: 59.941
Do you have QuickTime Player installed on the PC.
Screen shot, I assume you have created a Jpeg image.
The maximum size for Attachments is 256Kb
Use the “Attachments” option (bottom of post) do not use the IMG tags.
BowleyC73
- ram: 4GB
Hi - yes I have Quick Time and have just updated to latest version. The screenshot is attached now. Thank you
BowleyC73
- ram: 4GB
Hope the screenshot helps. If you could give me any assistance that would be great.
have you tried changing the file extension to .mov - it worked for the user with the same problem in the topic I pointed you to in my post above
BowleyC73
- ram: 4GB
No i haven't tried that. How can i do it?
you open Windows Explorer (or my computer) and browse to the file - if it says something like "abcdefg.mp4" you use the rename option to change it to "abcdefg.mov" - you will receive a warning message about changing extensions but just cancel that.
If you do not see the .mp4 bit on the end then click on "Organise" in the top right corner of your file browser - then click on "Folder and search options" - then on the "view" tab at the top of the dialogue window - then untick the box against "Hide extensions for known file types" - then click OK - go back to your file and check and try again.
In Windows Explor/Computer, right click on the file and choose 'Rename". Just rename the 'mp4' part to 'mov'. Make sure, though, that you have Quicktime installed on your computer.
BowleyC73
- ram: 4GB
Thank you! I
will try that now.
BowleyC73
- ram: 4GB
Thank You for the help it works now!
