Can't use ColorFast on overlay track?
Brucewh
operating_system: Windows 8.1
motherboard: AMD PEGATRON CORPORATION VIOLET3 5.00
processor: 2.80 gigahertz AMD Phenom II X4 925
ram: 8 GB
Video Card: ATI Radeon HD 4650
Hard_Drive_Capacity: 2000 GB
Monitor/Display Make & Model: LG W2453
Post by Brucewh »
Okay, maybe I'm missing something obvious here. I've installed NewBlue ColorFast, and it shows up in VS X6 as expected. If I drag and drop it onto the video track, the changes I make apply, no problem. But if I drag and drop it onto the overlay track, then make the changes I need, they don't stick … they go away when the dialogue is closed. Is this filter limited to the video track only? Or do I have a problem here?
Kingston
motherboard: Gateway [Acer] DX4860
processor: Intel Core i5 3rd gen. 3 GHz
ram: 8 GB
Video Card: Intel HD 2500
sound_card: Bluetooth
Hard_Drive_Capacity: 1 TB
Monitor/Display Make & Model: Dell ST2210; Samsung SmartTV 3D 40"
Re: Can't use ColorFast on overlay track?
Post by Kingston »
I don't have any problems here with the overlay track and Colorfast. Did you have keyframes turned on after you opened Colorfast? That's one of it's options. If you leave it turned on, and don't keyframe anything else, then the effect fades in until the middle of the clip and then fades out to the end of the clip. So if the timeline cursor is at the beginning of the clip, you won't see any effect. The effect will be full on at the middle of the clip, and then full off at then end of the clip.
I make a habit of turning off keyframes the first thing when I open the Colorfast dialog. That's how it is with most of the NewBlue effects.
Brucewh
ram: 8 GB
Post by Brucewh »
Well, I tried it on the overlay track with keyframes at the beginning and end of the clip, and without using keyframes. The preview in the ColorFast dialogue displays my changes accurately. However, the only way to close the dialog after the settings are complete is to click the red X in the top right-hand corner. There is nothing along the lines of an "Apply" or "Okay" button in the dialogue, so there's no other way out. Nevertheless, when I use it on the main video track, my settings are saved. When I try it on the overlay track, clicking the red X seems to cancel everything I've done.
Incidentally, this seems to be the only NewBlue effect filter that gives me this problem. Sigh.
Hi Bruce
The ColorFast panel is quite large.
I see two buttons lower left, OK and Cancel scroll down using the windows slider far right.
I guess Corel are trying to make the panel as large as possible
Kingston
ram: 8 GB
Post by Kingston »
As Trevor said, the OK and Cancel buttons are hidden at the bottom. You have to use the scroll bar to get to them.
Of course when you click the red X, you are cancelling what you set up. That applies throughout Microsoft Windows.
Brucewh
ram: 8 GB
Post by Brucewh »
I looked at that dialogue box a dozen times and didn't spot that slider. Feel like such a dolt. In my (weak) defense, it is a skinny slider that blends in with the dialogue box frame. And it blends in with the more visible slider for the presets panel at the bottom. Also confusing is that the vertical sliders are distinctly different, visibly, from the horizontal slider for the timeline. Anyway, thank you for the clue … I am somewhat less clueless than I was before. I appreciate it.
canuck
Post by canuck »
Bruce, don't feel like a dolt. Corel VS must have one of the worst interface designs when it comes to color.
