PSP X4 - how to remove folders created on load
stevetuk
Post by stevetuk »
Hi, newbie here. I have an issue with PSP X4; on load the program creates folders in the root of my network drive ( M:\ ) including:
  • Brushes
  • Bump maps
  • CMYK profiles
  • Deformation maps
    [*Displacement maps
  • and so on...
I have deleted these folders manually and they are recreated each time PSP launches. I have changed the settings in File -> Preferences -> File Locations to remove references to these folder locations, and then tried deleting them, but they are recreated again on load.
Does anyone know how to remove them? They are littering my network drive...TIA.
Cassel
ram: 16Gb
Corel programs: PSP 8 (JASC) to PSP 2023
Re: PSP X4 - how to remove folders created on load
Post by Cassel »
From experience, it looks like they are there to stay, unfortunately.
Cassel
https://scrapbookcampus.com
LindaSue
motherboard: Gigabyte
processor: 2.71GHz AMD Athlon II X2 215 processor
ram: 3 GB
Video Card: ATI Radeon HD 4350
sound_card: Realtek AC97 Audio [onboard]
Hard_Drive_Capacity: 1320 GB
Monitor/Display Make & Model: Asus MX279 HDMI 27-inch
Corel programs: Paint Shop Pro X2, X4, X6
Post by LindaSue »
They shouldn't be installing themselves in the root of your drive. They should appear in the My Documents/Corel PaintShop Pro folder or whatever they're calling My Documents on Windows 7 or 8.
Using Paint Shop Pro versions 5, 6, 7, 8, 9, 12, 14, 16
motherboard: Alienware M17xR4
ram: 6 GB
Hard_Drive_Capacity: 500GB
Corel programs: PSP: 8-2023
Post by LeviFiction »
The root of a network drive at that with a completely different drive letter.
Could blame it on moving the My Documents folder to the network drive. If stevetuk moved the My Documents folder to the network drive using the location property that would explain why PSP keeps adding these files to the network drive instead of the regular C drive. But that wouldn't explain why PSP isn't creating the normal "\Corel PaintShop Pro\15.0\*" folder structure. And that's a big speculation, if stevetuk didn't move the My Documents folder this shouldn't be happening at all.
stevetuk
Post by stevetuk »
Sorry I missed the replies until now.
There is a My Documents folder on the network drive (M: for sake of reference).
I.e. M:\My Documents
There are no PSP-generated subfolders in there. They are all in root, e.g.
M:\Brushes
M:\Bump Maps
M:\CMYK Profiles
There is a Corel\Corel PaintShop Pro X4 folder in C:\ where the program is installed, but there isn't a subfolder called \15.0\* in there. Should there be?
If I moved the folders from root of M:\ to M:\My Documents\Corel PaintShop Pro\15.0\* do you think they'll stay and not end up re-created in root of M:\? Worth a try I suppose!
ram: 6 GB
No, 15.0 is just what mine is because I have X5.
As for whether or not they'll stay in the Corel folder. My guess would be no. It seems insistent upon having them on the root of the networked drive.
But you could always try.
photodrawken
ram: 16Gb
Hard_Drive_Capacity: 324Gb
Post by photodrawken »
stevetuk wrote:There is a My Documents folder on the network drive (M: for sake of reference).
My thought is that it has to do with how the network drive is being recognized. Have you assigned a "real" drive letter to it?
Ken
stevetuk
Post by stevetuk »
Well my attempt failed, as you thought: the folders were recreated in the root of the network drive again.
The drive does have a drive letter assigned as mentioned above, sorry my fault for not being clear; the drive is M:
It's odd because surely in the absence of a network drive it wouldn't be creating these in root of C:\ ?
photodrawken
ram: 16Gb
I'm out of specific things to try, other than using PSP's Preferences...File Locations to ensure the locations listed are correct for your setup.
If that doesn't cure it, you'd still be left with two possibilities:
1. A bug in PSPX4. (Do you have its latest service pack installed?)
2. Something in your network configuration that's translating or mapping what PSP thinks is its My Documents subdirectory to the root of that networked drive.
Could be a nasty one to track down :cry: Good luck.
Ken
hartpaul
ram: 8 Gb
Hard_Drive_Capacity: 1000 Gb
Post by hartpaul »
Can you try installing with the Network drive turned off, so that it has no choice but to create those files originally on your C drive in My documents. Then after it is established and works a couple of times turn your M drive on and see if it behaves itself.
stevetuk
Post by stevetuk »
Ok, no success - I managed to disconnect my network drive, installed PSP 4X and then tried to load it to see if it generated the folders again only this time I just had a CTD:
Problem signature:
Problem Event Name: APPCRASH
Application Name: Corel PaintShop Pro.exe
Application Version: 14.2.0.88
Application Timestamp: 4faccf07
Fault Module Name: ntdll.dll
Fault Module Version: 6.1.7600.16915
Fault Module Timestamp: 4ec49caf
Exception Code: c00000fd
Exception Offset: 00046892
OS Version: 6.1.7600.2.0.0.256.4
Locale ID: 2057
Additional Information 1: a090
Additional Information 2: a090701530654d4051219c2ce97055ba
Additional Information 3: b355
Additional Information 4: b355a683e2777c01277fe60f9831d7d8
Any ideas? I haven't reconnected my network drive yet - will test that first.
stevetuk
Post by stevetuk »
Quick update: when I reconnected my network drive and tried to open PSP X4 it worked without any problems - and then duly recreated those folders...
ram: 6 GB
If your network drive is setup as your userprofile or as your My Documents folder specifically, as in Windows is redirecting the profile or specific folder to this network drive then PSP will attempt to write there.
You mentioned before that the My Documents folder is inside this network drive. Did you tell Windows to relocate your My Documents folder to the network drive?
It's possible PSP can't handle this.
In which case the only real resolution is to either not use the network drive to host My Documents or to contact Corel's paid support and see if they can offer anything.
