Export of resized files
Bugs & Suggestions
cookiebob
operating_system: Linux
System_Drive: N/A
processor: Intel Core i5 CPU M 460 2.53GHz x4
ram: 4GB
Video Card: Intel Ironlake Mobile
Hard_Drive_Capacity: 320GB
Monitor/Display Make & Model: Asus
Post by cookiebob »
Hi all,
in my batch settings I've selected images to be resized on jpeg-export to "Resize Long/Short" to "2048x1365 [long/short]". Some of my images (in landscape format) are indeed 2048x1365, though others are 2047x1365 or 2048x1360. Why is it so? :shock: Thanks for your hints! :wink:
afx
System_Drive: N/A
Video Card: FirePro 4900
Re: Export of resized files
Post by afx »
The aspect ratio is not changed in the batch queue. You only define the bounding envelope that the image has to fit in. So if your image does not have the exact aspect ratio that fits the constraints, one of the sides will be shorter than specified.
cheers
afx
cookiebob
System_Drive: N/A
ram: 4GB
Post by cookiebob »
I don't understand this frankly. Yes, some images have been cropped inside ASP, but always in 3:2 ratio. That's why I'm confused why some outputs are different than other...
Through all my exports the same size is preferable as those images are being uploaded to my website - if there's a difference you can see it in comparison :?
afx
System_Drive: N/A
Post by afx »
Use the larger value in both fields, that makes life a lot easier....
cheers
afx
