AfterShotPro does not start anymore
Bugs & Suggestions
gerd
operating_system: Linux
System_Drive: N/A
processor: i7-3770
ram: 32GB
Video Card: NV280 + NV S310
Monitor/Display Make & Model: Lacie324/...
Post by gerd »
AfterShotPro does not start anymore: Log show "Error -6"
Log:
Install Path: /opt/AfterShotPro
LD_PATH: /opt/AfterShotPro/lib:
XLIB_SKIP_ARGB_VISUALS: 1
0.0: I have SSE2
0.20: Bibble program arguments ("./AfterShotPro")
0.21: Loaded "/opt/AfterShotPro/supportfiles/locale/aftershot_de.qm"
0.21: Loaded "/opt/AfterShotPro/supportfiles/locale/qt_de.qm"
0.21: Loading plugins
0.27: AfterShot Pro key used. 6
0.27: System locale: en_US
0.30: Added plugin locale file: "/opt/AfterShotPro/supportfiles/plugins/Equalizer.afplugin/locale/Equalizer_de.qm"
0.30: Added plugin locale file: "/opt/AfterShotPro/supportfiles/plugins/Nostalgia.afplugin/locale/Nostalgia_de.qm"
0.31: Loaded "/opt/AfterShotPro/supportfiles/locale/aftershot_de.qm"
0.31: Loaded "/opt/AfterShotPro/supportfiles/locale/qt_de.qm"
0.31: Loaded "/opt/AfterShotPro/supportfiles/plugins/Equalizer.afplugin/locale/Equalizer_de.qm"
0.31: Loaded "/opt/AfterShotPro/supportfiles/plugins/Nostalgia.afplugin/locale/Nostalgia_de.qm"
0.73: AfterShot Pro key used. 6
0.84: AfterShot Pro key used. 6
0.84: AfterShot vers.: 1.1.1.10
0.84: Built on: "Thu Jan 31 2013"
0.84: Language: de
0.84: App Path: /opt/AfterShotPro/bin/AfterShotPro
0.84: System Home: ../supportfiles
0.84: User Home: /home/gerd/.AfterShotPro
0.84: Prefs Home: /home/gerd/.config/Corel/AfterShot Pro.conf
0.84: Platform: Linux
0.84: Issue: "Debian GNU/Linux 7.0 \n \l"
0.84: Kernel: "Linux version 3.2.0-4-amd64 (debian-kernel@lists.debian.org) (gcc version 4.6.3 (Debian 4.6.3-15) ) #1 SMP Debian 3.2.41-2"
0.85: Build Mode: Release
0.85: Product Name: "AfterShot Pro"
0.85: AfterShot Pro key used. 6
0.85: Registered Version
0.85: Initializing
0.85: Cpu Manager init: 8
0.85: **** Making CLManager
0.89: Got 1 platforms
0.89: OpenCL is disabled in low mem mode
0.89: platform 0xa7b24b0 "NVIDIA Corporation" OpenCL Version: "OpenCL 1.1 CUDA 4.2.1"
0.90: device: 0xa7b2420 "NVS 310"
0.90: device: 0xa7b2510 "Quadro NVS 290"
Fatal: Could not create context. Error -6
0.152: Could not create context. Error -6
Aborted
Any help/ideas ?
regards, Gerd
afx
System_Drive: N/A
Video Card: FirePro 4900
Re: AfterShotPro does not start anymore
Post by afx »
So what did you change? new Nidia driver?
cheers
afx
gerd
System_Drive: N/A
processor: i7-3770
ram: 32GB
Post by gerd »
afx wrote:So what did you change? new Nidia driver?
cheers
afx
This was one of the first ideas - but the last update was done with complete new install of the whole system (changing to 64bit, ext4 ). After that, ASP was running fine. From time to installation to now, only standard debian updates has been done as usual.
Is there a source to find out a better description, what "error -6 " says ?
regards, Gerd
afx
System_Drive: N/A
Post by afx »
Well, the standard debian updates might have changed something in the OpenCL libs.
I'd use "strace -o /tmp/as.log -ff" on the aftershot startup file and then see which thread has the error and what it tries to do before it.
the -6 might be a misinterpreted value (signed instead of unsigned...).
cheers
afx
gerd
System_Drive: N/A
processor: i7-3770
ram: 32GB
Post by gerd »
To add a bit more: ldd shows no missing libraroes or other errors. Before the crash, the splitcreen of AfterShotPro is visible for a very short time (not really readable).
strace end with the following lines:
mmap2(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0xfffffffff3b1a000
fstat64(11, {st_mode=S_IFREG|0644, st_size=1501, ...}) = 0
_llseek(11, 1501, [1501], SEEK_SET) = 0
fstat64(1, {st_mode=S_IFCHR|0600, st_rdev=makedev(136, 1), ...}) = 0
mmap2(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0xfffffffff3b19000
write(1, "Fatal: Could not create context."..., 43) = 43
write(2, "2.16: Could not create context. "..., 42) = 42
write(11, "2.16: Could not create context. "..., 42) = 42
close(11) = 0
munmap(0xf3b1a000, 4096) = 0
rt_sigprocmask(SIG_UNBLOCK, [ABRT], NULL, 8) = 0
tgkill(10364, 10364, SIGABRT) = 0
--- SIGABRT (Aborted) @ 0 (0) ---
+++ killed by SIGABRT +++
I'll try to attach to full output, maybe somebody can see more (I don't see the problem there, but I'm not a developer)
regards, Gerd
as_log.tar.bz2
Output strace
(24.39 KiB) Downloaded 285 times
afx
System_Drive: N/A
Post by afx »
Try to set
Preferences\OpenCL\Enabled=false
in
~/.config/Corel/AfterShot Pro.conf
cheers
afx
gerd
System_Drive: N/A
processor: i7-3770
ram: 32GB
Post by gerd »
Already done - without effect ..
cheers, Gerd
afx wrote:Try to set
in
cheers
afx
afx
System_Drive: N/A
Post by afx »
Drat.. No idea.
Try running it from a different account to see whether it is anything in the configuration.
cheers
afx
